Hackaday.io Hackaday.io
Sign up Log in
Home Climate Control
Hardware independent multi zone climate control system
vadim-tkachenkoVadim Tkachenko
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
0 comments
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
Public Chat
249
0
0
0
Team (1)
  • vadim-tkachenkoVadim Tkachenko
Join this project's team
  • Home Climate Control
Software
ongoing project
HVAC home automation ZIGBEE z-wave 1-wire xbee mqtt Android Remote control Climate control temperature zoning ventilation smart home observability influxdb ESP32 ESP8266
This project was created on 09/16/2023 and last updated 3 years ago.
Description
Create as many climates in your home as you never thought imaginable.
Control temperature, humidity and ventilation.
Do it on a schedule.
Have everything measured and recorded.
Do it from anywhere.
Project Logs
Collapse
  • Complete configuration guide published
    Vadim Tkachenko • 09/16/2023 at 21:24 • 0 comments
    Configuration was always the Achilles' heel of this project. Now that there is a new, simplified YAML configuration, it was a good idea to document it as it was being developed.
    The configuration guide is a part of the active development branch, it will not bit rot like other sites inevitably did. Here: https://github.com/home-climate-control/dz/blob/reactive/docs/configuration/index.md
  • 23 years from the start, finally, docs
    Vadim Tkachenko • 09/16/2023 at 21:22 • 0 comments
    https://github.com/home-climate-control/dz/blob/reactive/docs/index.md - published on the active development branch, will make it to the home page when the development iteration is complete
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
Control the Heat Recovery Ventilator and Furnace Circulation Fan based on humidity and CO2 levels.
Project Owner Contributor
CO2 / Presence detection and HRV Control
adwiebeadwiebe
The Bee Comfy is a MCU-based climate control system for honeybees
Bee Cage Climate Control
criptastichackerCriptasticHacker
Innotronics presents Innohome, the smart home automation system that is the ultimate life hack.
Innohome
sarahekairebsarahekaireb
This project describes the kinematics of a "mouse bot" or wheelchair type of vehicle and presents a suitable control law for it
Control of a vehicle with two driving wheels
adriajunyent-ferreadria.junyent-ferre
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Home Climate Control", please tell us the reason.
Send message
Remove Member
