PCBLampWorkshop_ArduinoEdition-ProximitySensor_.ino.inoino - 2.74 kB - 04/06/2024 at 21:23 |
PCBLampWorkshop_ArduinoEdition-SimpleAccelerometer.inoArduino sketch to change the color of the LEDs using the BLE's accelerometerino - 3.94 kB - 04/05/2024 at 00:52 |
PCBLampWorkshop_ArduinoEdition-Microphone.inoArduino sketch to turn the LEDs on using the BLE's sound detectorino - 3.90 kB - 04/05/2024 at 00:52 |
PCBLampWorkshop_ArduinoEdition-GestureSensor.inoino - 4.23 kB - 04/05/2024 at 00:52 |
PCBLampWorkshop_ArduinoEdition-ColorSensor.inoArduino sketch to change the color of the LEDs on the boards with the BLE's color sensorino - 2.09 kB - 04/05/2024 at 00:52 |
PCBLampWorkshop_ArduinoEdition-Button.inoArduino sketch to turn the LEDs on with the controller board buttonino - 5.29 kB - 04/05/2024 at 00:52 |
PCBLampWorkshop_ArduinoEdition_Button-Simple.inoArduino sketch to turn the LEDs on with the controller board button (but simple)ino - 2.79 kB - 04/05/2024 at 00:52 |
PCB Lamp Workshop Arduino Edition - Controller board.stpSTEP Filestp - 15.23 MB - 11/08/2023 at 23:10 |
PCB Lamp Workshop Arduino Edition - Circle.stpSTEP Filestp - 1.99 MB - 11/08/2023 at 23:09 |
PCB Lamp Workshop Arduino Edition - Horseshoe.stpSTEP Filestp - 1.85 MB - 11/08/2023 at 23:09 |
PCB Lamp Workshop Arduino Edition - Line.stpSTEP Filestp - 1.32 MB - 11/08/2023 at 23:09 |
PCB Lamp Workshop Arduino Edition - Square.stpSTEP Filestp - 1.47 MB - 11/08/2023 at 23:09 |
PCB Lamp Workshop Arduino Edition - Controller and Lamp Board Outlines.aiAdobe Illustrator filepostscript - 367.94 kB - 11/08/2023 at 23:10 |
Data Sheet - 987650-6631.PDFFlat flex (ribbon) cable data sheethttps://www.digikey.com/en/products/detail/molex/0982670211/3469487 Adobe Portable Document Format - 913.87 kB - 09/20/2023 at 21:58 |
Data Sheet - WS2812B.pdfRGB LED's data sheetAdobe Portable Document Format - 347.03 kB - 09/20/2023 at 21:58 |
ABX00069-datasheet.pdfArduino Nano 33 BLE Sense Rev2 DatasheetAdobe Portable Document Format - 1.11 MB - 09/20/2023 at 21:51 |
91290A013_Alloy Steel Socket Head Screw.STEPSTEP fileSocket head screws preferred. https://www.mcmaster.com/91290A013/ step - 425.34 kB - 09/20/2023 at 21:45 |
90592A075_Steel Hex Nut.STEPSTEP filehttps://www.mcmaster.com/90592A075/ step - 243.57 kB - 09/20/2023 at 21:45 |
91290A013_Alloy Steel Socket Head Screw.PDFhttps://www.mcmaster.com/91290A013/Adobe Portable Document Format - 134.61 kB - 09/20/2023 at 21:45 |
90592A075_Steel Hex Nut.PDFhttps://www.mcmaster.com/90592A075/Adobe Portable Document Format - 102.61 kB - 09/20/2023 at 21:45 |
Supplyframe DesignLab
