1Step 1: Unpack & Repack
Prerequisite
- ubireader
- mkfs.ubifs and ubinize (search how to install them)
Step 1.1: Unpack system_unlocked.img
ubireader_extract_images system_unlocked.img -o system_u cd ./system_u/system_unlocked.img/
Now you will get a file with a .ubifs extension.
In my case, it's "img-35657280_vol-rootfs.ubifs"Step 1.2: Unpack ubifs
ubireader_extract_files -k -o ./rootfs img-35657280_vol-rootfs.ubifs
You will now have a folder named "rootfs" containing all system files.
Step 1.3: <Modify Firmware>
Step 1.4: Repack .ubifs
mkfs.ubifs -m 2048 -e 126976 -c 1073 -x lzo -f 8 -k r5 -p 1 -l 5 -F -r ./rootfs/ rootfs.ubivol
Set up the config.ini file:
touch config.ini echo "[rootfs-volume] mode=ubi image=rootfs.ubivol vol_id=0 vol_size=27807744 vol_type=dynamic vol_name=rootfs" > config.ini
Change the "vol_size" value when the firmware is modified. Keep it as is unless you encounter size-related errors.
If you do encounter size-related errors, the error will have the 'vol_size' that needs to be set.
Step 1.5: Repack img
ubinize -p 131072 -m 2048 -o system_m.img ./config.ini
You will now have the modified firmware (system_m.img) ready to be flashed using fastboot.
Step 1.6: Flash using fastboot
How to Boot in Fastboot:
- Remove battery from JioFi 3
- Locate reset pin hole button
- Lay down JioFi 3
- Use Paper Clip / SIM Ejector Tool to press button inside (using sharp object is not recommended)
- Keep pressing button down and insert USB cable
- Release button as soon as all the LEDs in Display turns RED. This means device is in boot loader mode
fastboot erase system && fastboot flash system system_m.img && fastboot reboot
