HB63C09M - 10x10 HD63C09 Based SBC
This is my project page for my new home brew computer, a multi-processor 63c09 and AVR SBC.
Here is a 63C09 SBC with an AVR companion chip, and they share the bus. Supports Similar iOS filesystem calls (like the Z80-MBC). Software is loaded to ram from the SD card by the CPU and the AVR pre-stages the top of RAM at boot up. The Full system bus is available from the mezzanine connection, which is available to the developer using a "request low" style Io request from an off board address decoder with an open collector output.
Scope of the project:
Scope of project is to get a AVR and a 63C09 to share the bus so the 63C09 has access to modern serial protocols, timers and other modern nice stuff.  The Current prototype in breadboard form accomplishes this.  The PCB prototype will be for finishing the firmware and testing chip set improvements so that we can reduce the chip count.
The running schematics will always be in the files section, thanks for checking out the project
Quick Jumps:
Relevant articles (newest first):
Files section and license :
AUTODIDACT WARNING!!
I am a HFC designer with the equivalent work experience enough to call myself a civil / mechanical engineer in my day job. Essentially, I design large scale metropolitan area fiber optic and RF utility networks.  I have an Associates in Computer Hardware, and an embarrassingly high number of industry certifications from an ongoing 20 year carrier in telecommunications engineering.  I don't have any formal EE training but I read A LOT.
I am a hobbyist with over 40 years of practice in the area of home brew computing!
There are aspects of this design which do not, due to a lack of training on my part adhere to what might be commonly held best practices. In general all of my projects should not be considered to adhere to any 'high speed' design principles. I try to verify everything I do on my bench, but everything is 100% at your own risk.  I don't make any guarantees, which is outlined in the very easy to understand CERN-OHL-P License
Sponsorship:
Once again, PCB Way has again kindly offered to sponsor the prototyping costs for this project.  PCBWay manufactures quality PCB's, 3d prints, as well as does metal fabrication.  Additionally they sponsor student projects, and hobbyist's open hardware projects.  Talking with any one of their sales staff for even a short amount of time it is clear they truly do care about the next generation of engineers and about the importance of open hardware designs.
Without the generous help offered, it would be difficult for me to complete these projects just simply due to the cost associated, and for that I am truly grateful.   So for your next project why not check out the services that they offer?
Thank you, PCBWay
BOM Digi-Key AHC Logic (reviesed).ods
Digikey parts list with typo fixed
spreadsheet - 39.51 kB - 11/05/2024 at 18:07
Download
BOM Mouser AHC Logic.ods
Mouser Parts Numbers BOM
spreadsheet - 46.45 kB - 11/05/2024 at 02:31
Download
Gerber_HB68C09-REV-4.2-10x10-SBC-63C09M-P_PCB_HB63C09-REV4-10(Squared)-4.2_2024-11-04.zip
Gerber Files for 4.2
Zip Archive - 855.13 kB - 11/05/2024 at 02:31
Download
HB68C09 - REV 4.2 - 10x10 SBC 63C09M Prerelease.pdf
Rev 4.2 10x10 4 layer through hole PCB
Adobe Portable Document Format - 72.31 kB - 11/05/2024 at 02:30
Preview
Schematic_HB68C09 - REV 3 - Mini ITX Form Factor 63C09 Motherboard_2024-01-04.pdf
Rev 3 prototype schematic
Adobe Portable Document Format - 288.64 kB - 01/04/2024 at 19:27
Preview
View all 6 files
  • Rev 4.2 Form Factor change, Project release!
    Dave Collins11/04/2024 at 20:15 0 comments
    Intro and Forward:
    The HB63C09M was an idea I hatched back two years ago when I was finishing up my first home-brew computer the HB6809. But it goes back further than that. The beginning is really around 2020 when I started building kit computers as a means to pass the time during the pandemic. I had purchased a kit from McJohn in Italy called the Z80-MBC2, by Fabio Defabis – an excellent little computer kit with a single logic chip, atmega32, Z80 CPU and a RAM chip. I was hooked on the small form factor and the things that I could do with my little computer. I made a few hardware expansions for it, most notably a joystick interface for my Tetris clone that I had programmed in pascal. At the time there were people asking Fabio on the Facebook group for the project if he was going to do other processors. Before long he was working on the V20-MBC (which I built) and later he went on to make the 68K-MBC which is architecturally slightly different. After a while, no new MBC computers were made, and by then I was on to building my 6809 based system, and still quite a novice at this (I am still!)
    Things happened life got busy I spent some time working on other projects and about a year ago started playing around with Arduino – and digging very deeply into the Z80-MBC2. I really wanted to understand how memory was loaded using a microcontroller and I wanted to know how Fabio had shared the bus with the Z80. Right around the same time I had also stumbled onto an even older work, Brad Rodreguez’s “Scroungemaster” and I fell in love. The scroungemaster is (well was) a concept for a 6809 multi-processing build Brad had built on wire wrap. He had used a rather simple circuit to do clock stretching in order to hand off cleanly to the other CPU’s into common ram. He detailed this in a paper entitled “Multiprocessing for the Impoverished” (found at https://www.bradrodriguez.com/papers/) I quietly started to play around with the design and build a small expansion for the HB6809 that allowed me to use an Arduino like a peripheral without a latch simply by stretching the clock.
    In his paper, Brad discusses the parallels between the Z80 and the 6809. I found a lot of parallels in my Arduino sketch and the work that Fabio had done with the Z80-MBC2, and after a few months I had a working prototype that could stage itself from the Arduino (at the time using latches) and boot into a machine language monitor. After that I streamlined the design, making it slightly more like the Z80-MBC2’s little brother the Z80-MBC by opening up a few address lines to the Arduino and then additionally solving a very difficult timing problem by changing from a controller generated clock to a synchronous clock (both the 63C09’s internal clock and the ATMEGA32 are clocked by the same 20Mhz crystal) and the board fully stages from ROM files saved to the SD card. No Rom code exists on the AVR EEPROM (save a small less than 40 byte program that bootstraps from the SD card). This allows the programmer and user to switch between environments without having to Flash a ROM onto the computer!
    After a few revisions of the board, I found I could further shrink the form factor to a smaller 10x10 PCB – albeit 4 layers. The Exact same size PCB as the Z80-MBC2! For me, it was like coming full circle, and now I think I am ready to share this design with others. What I have is a fully functioning – ready to go 63C09 playground. But there's still some work on the software, this is where you come in.
    What I am calling this board revision is “The Prerelease” edition. Essentially the hardware is finished. From this point, any and all architecture changes will need to be approved by the “Community” -- what that means specifically will have to depend on the group of developers that go ahead and early adopt the design for the express purpose of porting software to it. For now there is enough (really) for people to start...
  • Sharing the bus with an Arduino without a latch
    Dave Collins01/21/2024 at 02:09 1 comment
    REV3 Works and synchronization scales exactly as expected!
    In short, the REV3 prototype is running at 20MHz. All of the underlying functionality is synchronizing, scaled up from 16MHz with zero issues. I am ecstatic and want to thank PCBWay for getting the prototype to a stable state by again covering a 2nd run of the mini ITX PCB. They have always been a wonderful partner in retro and I would not be able to operate nearly as quickly as I do without their help.
    The problem of the REV1 Prototype:
    What we learned from REV1 specifically is, using the AVR to Clock the CPU is bad because we don’t know (inside the context of the code) where the CPU clock is at when we send the IOGNT_ signal as it is interrupt timer driven. Generally the best we can do is guess, and insert a delay (as the AVR in REV1 was clocked at 16 Mhz and the CPU was clocked at 4Mhz). Guessing is bad as there is, turns out – a lot that can happen to delay or decrease the period of time the AVR takes to finish this process. This causes a bit of instability and made it generally impossible to move forward on optimizing things.
    How does the AVR share the bus with the HD63C09?
    The bus arbitration was switched from active arbitration (REV1) where delays were used to insure the IOGNT_ was held long enough to prevent MRDY from bouncing, to passive synchronized arbitration (REV2 and REV3).   Essentially what this means is, both CPU's are using the same system clock and so every 4 cycles they finish their current cycle at the same time. To really understand requires some explanation, This all comes down to the specific timing of the 63C09’s decode cycle.
    the following timing diagrams snap to the system clock, this is to show how the clock synchronization works vs actually showing the nS to nS events, some edges happen just before or after they are drawn here so for simplicity sake - please pardon that inaccuracy.
    The 63C09 creates the quadrature clock’s (E & Q) which are 90 degrees offset from each other. In the case of the HB63C09M these clocks run at ¼ the system clock due to a simple internal clock divider that uses a set of J/K Flip Flops (each flip flop divides by 2). The 63C09E (‘E’ for external) generates this clock external to the chip, which opens up some of the 40 pin package for extra signals which are useful for more traditional bus arbitration. Both CPU’s have the option of using a clock stretching circuit which allows the designer to “hold over” or stretch the clock by up to 5uS. This 5uS limitation is to allow the CPU to refresh its internal dynamic registers to avoid data corruption. I briefly went over this in REV1 architecture overview.
    While significant changes have occurred within the selection chip set, the request grant circuit remains consistent. In this circuit, the AVR typically keeps the IOGNT_ signal high, except when it intends to relinquish control of the data bus to the CPU. When the CPU reads or writes to 0xA000 – 0xAFFF, this generates an IO request via the address decoder. Once the IO request is initiated, the address decoder generates a low signal that, after passing through an inverter to one input of the NAND gate, sets the output low as long as the leg tied to IOGNT_ is high. This output is tied to the MRDY signal on the CPU and begins a clock stretch. This state persists until the IOGNT_ signal pulsed low by the AVR for exactly ½ cycle of E.
    REV2/3 Decode / Bus Arbitration Circuit
    Simple enough right? But what if we release IOGNT_ before the IO Request ends (less than ½ of E)? In short, we would have a problem. Since it’s just a passive logic circuit it would compute the result and pass it along to essentially the MRDY line causing it to bounce a few nS before the IO request finishes – this may trigger a second clock stretch early, or cause other unpredictable things to happen on the busses or inside the CPU which usually just result in a non working system.
    So...
  • REV3 Prototype chipset overview
    Dave Collins01/04/2024 at 19:58 0 comments
    REV3 Board
    REV3 Board Render (top)
    The Rev3 Board is basically a copy of the hand wired Rev2, itself a retrofit HB6809.   The Hand wired prototype (see below) was more or less the new chip set design, along with a very stable pierce oscillator I built in about 2 weeks time working nights.    What was accomplished  with the REV2 build was considerably faster clock, which clocks both the 63C09 and the AVR simultaneously at 16 Mhz.  The plan is to push the Rev3 to 20 Mhz.   In order to do this it was clear I had to make some tough choices about the chip set.  Looking back at the failings of the REV1 board, one of the biggest issues was chip count and latency.   These things didn't matter as much on the breadboard prototype as it ran an asynchronous clock (similar to the Z80-MBC2) with the AVR clock coming from a crystal oscillator, and the AVR it's self clocking the 63C09 at 1/4 to 1/2 it's clock.  But when I translated that design it didn't seem to work well on the PCB.   This coupled with several mistakes made while documenting the Big mess of wires breadboard, and in the actual routing mistakes the whole board was more or less a non starter.
    REV2 hand wired board
    What I learned from the REV1 board is to fit all of these components comfortably on a Mini ITX motherboard, I needed to reduce the chip count to make all of the connections fit (or go to a significantly more expensive multi-layer board).  In order to do this I had to significantly reduce the chip count, and in the case of the bank selection circuitry I further reduced the space the chips take up by both simplifying the the design and choosing different parts.  A few of you have commented that it might be simpler to just roll together a custom ULA for the design.  I think that this makes a lot of sense, but the trouble with that approach is that it may become harder to find CPLD / GAL parts as replacements.  This is not the case using standard 74 series parts, and as you will see below the design is very simplified to what I could determine as the fewest possible parts to accomplish what was needed.
    New memory map:
    The simplified memory map made using less logic chips for address decoding significantly more obtainable.
    ROM / RAM Configuration
    Addreses 64K Main Address Space
    B000-FFFF Upper Fixed Ram 20K Physical Rom Space (
    A000-AFFF Device Address Space for MCU and Mezzanine connection
    4000-9FFF Lower Fixed 24K Fixed Lower Ram Bank
    0000-3FFF Memory Bank Window, set by bank register (16K)
    128K RAM Chip Layout
    1C000-1FFFF Bank 7 (16K)
    18000-1BFFF Bank 6 (16K)
    14000-17FFF Bank 5 (16K)
    10000-13FFF Bank 4 (16K)
    C000-FFFF Bank 3 (16K)
    A000-BFFF Bank 2 Usable – 8K of usable space 2000-3FFF in bank address
    8000-9FFF Bank 2 Lower Fixed Ram Bank top 8K of Memory “Shadow”
    4000-7FFF Bank 1 Lower Fixed Ram bank bottom 16K
    0000-3FFF Bank 0 (16K) system boots with this bank loaded giving 40k cont.
    “Bank2” selects the ram chip between 8000-BFFF.  When this bank is selected, 0000-1FFF (in the bank) will map to the last 8K of the fixed RAM area (in the 64k address space of the CPU). Whereas 2000-3FFF is available for use for programs. Overwriting the bottom 8K will cause data corruption in the top of the fixed RAM area (in the 64k address space of the CPU), As this is effectively the same area on the ram chip.
    In “RAM Only mode” the address range B000 – FFFF is physically writable at that CPU physical address as the ROM is disabled.  This can be configured on the board by removing the “ROM Enable” jumper
    and moving the Ram selection Jumper to “RAM” In this mode the AVR needs to be configured to update the ram from SD at boot. This is not yet implemented
    The bank selection...
  • REV1 PCB Pitfalls, whats next?
    Dave Collins10/21/2023 at 21:30 0 comments
    Reflections:
    General reflections from last time
    Well you read the title here, so its not hard to guess what the outcome from the first PCB run was.  In short, the 1st PCB design has issues.
    I tried working evenings for the last week to get it to come to life, however there are a ton of stability and possibly further routing mistakes that meant that all scaled into very bad ringing, noise and timing issues.  To be clear, none of this is the manufacturers fault. All the issues and pitfalls in this design lie solely on my shoulders.  I have plans to fix the issues, but its going to take some time and a step back to really understand  the problem.
    What is next?
    I want to take a step back and look at the design in pieces.  I still have a handful of boards left over from the HB6809, There's ample prototyping space on there for me to experiment with.  This weekend I want to start by building a very simple but very stable Pierce oscillator,  and see if I can get the CPU, RAM and ROM to come up on a 16Mhz base clock.  Once this works I will work to add subsystems and to a much better job of documenting the build up as I go.
    On the firmware side over the next two weeks I want to focus on getting the RAM to stage on the breadboard build without using the latches.  I think I can use the CPU to stage it's own ROM space by feeding it one byte of machine code at a time running in peripheral mode (I discuss this in the architecture overview) .  This will further get the chip count down, which is important because the end goal is to have a computer that is built on 10cm x 10cm boards (or less) and currently they are 170x170 so we need almost a 50% reduction, or to switch to a mini frame design with expansion headers that link the boards together.  I also DO still want a 68C09 motherboard that just drops into a PC case, because that was the whole idea in the first place, but a lower cost version would also be nice in terms of making the design more accessible.
    PCB review how they hold up to rework:
    Speaking of the PCB's, I wanted to share my thoughts on the boards produced by PCBWay, what you get in  terms of cost for a large format board like this as well as what it's like to rework a two layer rapid turn PCB like this with manual tools.
    First, and I've touched on this before, PCBWay does a higher than average job on masking.  If you wanted to make a short run of boards with ENG or even Lead Free HASL, for commercial sale these boards really do hold up.  Nothing peels with normal handling, and it stands up to even the highest level of abuse.  The edge finishing is top notch, nothing is left with a sharp edge (unless you specify that, of course!) and I never felt like if I handled the boards without gloves that I would be cut or that the edges would catch on the work surface.  Other manufacturers in China do not take the time, as PCBWay does, to really get this right.
    As an example, the 14 pin socket had to be completely removed to rework trace mistakes that were made in the design files using just manual tools (which always require a level of care), I was able to remove the socket and replace with only minimal mask removal, and all of this was around pins which tie into board planes.   If I had a a reliable way to preheat the board none of this would have even been an issue given the finishing on the PCBs.
    On average, PCBWay is more of an expense.   But all of these touches are a value add, and I believe given the blazing fast turn around to North America, the quality really is worth the expense.  I would have no problem recommending them over the other producers in China, they do a great job with what you pay for. Additionally they don't over charge for shipping and have several options depending on your required turn around (which all obviously scale with the price.)  They also continue to offer a low price...
  • The architecture overview
    Dave Collins10/10/2023 at 03:25 0 comments
    As I wait for PCB's to arrive from PCBWay's factory in China, I thought I would spend a few moments to go over the general architecture of the computer.  We can start with a simple memory map:
    The computer consists of a single 128K low power SRAM, a Hitachi HD63C09 (internal clock version), an AVR ATMEGA32 micro controller, Latches, buffers and decoding logic.  The current plan is to load the memory from the micro controller while the system is in a halted state, and enter the reset vector on the system reset which is triggered by the AVR.  The 63C09 does all the heavy lifting and currently is clocked at 4 or 8 MHz, which provides an E strobe of 1 or 2 MHz.  No emulation, just 8 bit muscle applied in all the right places.  The AVR does NONE of the code of the computation this is solely a computer that can run native 6x09 machine code. There is some down the road planning to expand the CPU clock to a faster speed but there's a few hurdles to jump before we can get there.
    Sharing the bus the AVR as a peripheral:
    There's a number of little computers out there that operate along side a micro controller in various ways, sharing the bus in different ways.  The Z80-MBC2 (which shares a lot of design language with my project) uses a wait / grant architecture to make sure that only one CPU accesses the bus at a time.  For the fully static Z84C0010 - a modern Z80 variant, this is no particular difficult chore, as you can stop the CPU for even a long time and hand data off to the CPU via the bus, before it's latched and the CPU carries off on it's merry way.  The very popular Agon light uses an esp32 to produce VGA signal and communicates with the main system over a 1Mbit serial connection, now that seems like it might hamper performance, but for processors of the day with full speed parallel access to video memory that's faster than most 8 bit bus's of the era.
    Our build uses a similar request grant architecture to the Z80-MBC2:
    Just two gates, and a 138 decoder IC. A very basic circuit lifted from Brad Rodriguez's Scrounge master design, though due to reasons he lays out in later in his series on the scrounge master, he ended up going another way.  For us the circuit is perfect as the AVR solves most of the limits set by the original design, and we don't need the extra latch he uses for clock synchronization.   Essentially, the bus decoder waits until it see's a request in the Io-range of 0xB000 to 0xB3FF.  Once it is triggered it sends a signal to the two gate request/grant circuit which will send the output (mrdy) to a low state. This holds the CPU to the point in time right before it's data latch. The AVR controls  state of /iogrant and holds it high unless it is sending a 'grant' signal.  Once the data is either read from, or written to the bus the AVR sends /iogrant low which sends the output (mrdy) high.  A high signal on the mrdy signal lets the CPU pick up where it left of and it latches the data as 'E' falls.  This set up has three pitfalls.
    1. The CPU can not be held off longer than 6uS per its data sheet, it's registers are dynamic and need to be refreshed.
    2. The AVR has to control the low state of /iogrant using a timing delay generated by no-ops to prevent mrdy from 'bouncing low' before the request cycle has completed.
    3. the AVR can not 'be in two places at once' - that is; it can not control the timing on the grant signal AND clear the bus of the data port at the same time.
    We solve these problems thusly: First every operation has to be kept to 6uS -- this is 100% achievable using careful coding - even with C, however every opportunity to quit to the exit of the current poling loop must be taken.  Second, we carefully time the delay using an analog scope to properly calculate and test the exact delay, through testing this is approximately 500nS at 2 MHz and 1us at 1 Mhz. NOTE: this delay is not a part of the 6uS limitation...
View all 5 project logs
  • 1
    Solder The Flattest Components First (resistors / diodes)
    • resistors and diodes soldering the standing resistor R6 last (this is the E Clock pin resistor)
      • you can lay R6 Down sideways like this:
  • 2
    Solder the bypass capacitor
    followed by the small bypass capacitors (these are not polarized and go in any way – they are all the same value)
  • 3
    Solder the chips which are under the sockets
    then soldering U11, U4 and U3 (these are the two transceivers and the bank register). These must be soldered without a socket, completely flat to the board. Very likely if you make a mistake here it will be very hard to check as these chips are underneath the two 40 Pin DIP packages and can not be placed in a socket.
View all 15 instructions
Ken Yap wrote 11/05/2024 at 02:43 point
👍 Looks like a cool project. I have liked the 09 architecture for many years. I almost wish I had specimens in my junk box to use up, as it's my self-imposed policy not to buy NOS.
Dave Collins wrote 11/05/2024 at 04:31 point
I am going through the process of figuring out kitting these - and I will most likely be providing a CPU (verified to work) with the kits.  at this point it's verified Pulls - but you do get a working CPU and don't have to buy a glut of them and worry about where to store them or how to get rid of them.  Thanks for your kind words!
