Final
01/12/2024 at 15:24 • 0 commentsOn the last day, even though we had some problems with arduino, our project worked!
Arduino
01/12/2024 at 11:04 • 0 commentsThe door will close once a code is put on the keyborad. To do this we needed to code in arduino which we are all quite bad at so we started from the beginning with LEDs. We did loose quite a lot of time on this.
The door
01/12/2024 at 11:01 • 0 commentsThe door is an important part of our project as the whole point of our project is to close it. To close it we put a system with an electromagnetic magnet.
We had a few problems:
the box
01/12/2024 at 10:58 • 0 commentsI found the perfect box at home and enjoyed painting it. I had to do a bit of research for the decoration
Prototyping
01/12/2024 at 10:56 • 0 commentsWe then made a few prototypes with cardboard to visualise our ideas
Research
01/12/2024 at 10:54 • 0 commentsWe directly knew we wanted to an escape game box so we started off by doing research about themes and enigmas to we could use.
We also started making notes of enigmas as the most complicated thing was to have fun, not too complicated enigmas that allow the players to have a good time. Here ar our notes:
