First off, hats off to the OMRON documentation folk - somebody obviously loves their job!
MEMS Flow Sensors D6F Series Catalog
I'm using the D6F-PH5050AD4 sensor (i.e., the differential, +/- 500 Pa, with 4 mm hose barbs). Scroll on down to page 28, and they have a GITHUB code link!!!! How awesome is that.
Here are a few more links to info about the sensor:
I am, however, saddened that this sensor has been discontinued at Digikey.
I opted for the D6F-PH5050AD4, but that means you need a cable. I made my own, but you can buy the cable.
Next, I placed a PICO-W, pull up resistors, and cable onto a digikey proto board.
frederik.deswaef
Piotr Sperka
Supplyframe DesignLab
CaptMcAllister
For Clifton, NJ residents seeking reliable air conditioning solutions, look no further! With a range of reputable HVAC companies in the area, you're sure to find the perfect fit for your cooling needs. From installation to maintenance and repairs, these experts ensure your comfort, even on the hottest days. Don't sweat it—stay cool with Clifton's trusted air conditioning services! https://atlantic-heatingcooling.com/
