1Build the air hose
I made some air hoses. This was fun! I started with the 4 mm hose barb on the sensor, so found some 4 mm ID, 6 mm OD air hose on amazon.
Uxcell a13080200ux0301 Blue 9M 29.5Ft 6mm OD 4mm ID Polyurethane PU Air Hose Pipe Tube
The HRV has little ports in it, so picked up some air needles...
To keep the hose rigid at the interface to the needle, I got some 4 mm OD steel tube...
Here, I placed the tube in a vice, and cut it using a pipe cutter.
Then, I wrapped a small amount of tuck tape around the metal tube to raise the diameter so that it just fits in the air needle.
Then, slid the metal tube into the air hose, and the air needle over the metal tube. Next, I placed shrink wrap over the whole thing with a bit hanging over the air needle so that it holds the whole assembly together.
2Get the code from Github
Here is the code for the raspberry pi pico on GITHUB that I wrote:
3Here is the system measuring the pressure on my HRV!
Here are the air needles/hoses pressed into the measurement ports of the HRV, and the PICO board dangling off of the sensor (maybe I need a 3D printed case...).
So - the pressure drop across the HRV core (stale air side), is sitting at about 17.5 Pa. Joy! It is great to be able to measure small pressure drops like this with a barebones setup.
