Measuring HRV and other HVAC devices
Sometimes you just need a need a pressure sensor that can measure HVAC devices!
0 followers
I wanted to measure the pressure on my heat recovery ventilator (HRV). This device draws in fresh air from outside, and exhausts the stale building air to the outside. Most pressure sensors you find in the DIY sphere are for measuring a few PSI, but what you need is to measure up to around a hundred pascals.
First off, hats off to the OMRON documentation folk - somebody obviously loves their job!
MEMS Flow Sensors D6F Series Catalog
I'm using the D6F-PH5050AD4 sensor (i.e., the differential, +/- 500 Pa, with 4 mm hose barbs).  Scroll on down to page 28, and they have a GITHUB code link!!!!  How awesome is that.
OMRON github! Yeah!
Here are a few more links to info about the sensor:
OMRON user manual
OMRON app note
I am, however, saddened that this sensor has been discontinued at Digikey.
I opted for the D6F-PH5050AD4, but that means you need a cable.  I made my own, but you can buy the cable.
2JCIE-HARNESS-02
Next, I placed a PICO-W, pull up resistors, and cable onto a digikey proto board.
DKS-SOLDERBREADBOX1
View project log
View all 3 instructions
cchambers1.1974 wrote 04/18/2024 at 05:58 point
For Clifton, NJ residents seeking reliable air conditioning solutions, look no further! With a range of reputable HVAC companies in the area, you're sure to find the perfect fit for your cooling needs. From installation to maintenance and repairs, these experts ensure your comfort, even on the hottest days. Don't sweat it—stay cool with Clifton's trusted air conditioning services! https://atlantic-heatingcooling.com/
