Implement a PM 2.5 sensor with Internet and Twitter connectivity to track air quality with a low cost device.
sensorV2.jpgJPEG Image - 917.93 kB - 06/14/2017 at 02:36 |
SomeData.JPGCapturing some Test data and testing postings in ThingspeakJPEG Image - 57.58 kB - 05/26/2017 at 22:00 |
SENSORTEST1.jpgThe PM2.5-PM10 Sensor is here!!! Running some tests... it seems it will require calibration.JPEG Image - 98.54 kB - 05/26/2017 at 21:57 |
This version includes a Fan added to the PPD42N sensor to increase the air flow, a 10K resistor from pin 5 of the sensor to GND to improve measure accuracy and the addition of sensor SHT1x to measure humidity and temperature.
The sensor is here but it seems it will require some calibration. It currently shows some PM10 data but a lot of Zeros in PM 2.5 data. Some research has shown that I need to add a case and a fan.
Currently taking measures of Temperature and Humidity. Cancelled measures of CO, MQ7 sensor requires modifications to be more accurate. Still waiting for PM2.5 sensor.
Check measures here: aire.valenciasanchez.com
