​Design of system
06/14/2017 at 02:34 • 0 commentsThis version includes a Fan added to the PPD42N sensor to increase the air flow, a 10K resistor from pin 5 of the sensor to GND to improve measure accuracy and the addition of sensor SHT1x to measure humidity and temperature.
The sensor is here!
05/26/2017 at 22:03 • 0 commentsThe sensor is here but it seems it will require some calibration. It currently shows some PM10 data but a lot of Zeros in PM 2.5 data. Some research has shown that I need to add a case and a fan.
Taking measures
05/18/2017 at 16:33 • 0 commentsCurrently taking measures of Temperature and Humidity. Cancelled measures of CO, MQ7 sensor requires modifications to be more accurate. Still waiting for PM2.5 sensor.
Check measures here: aire.valenciasanchez.com
