FRONT AXLE
02/12/2024 at 03:21 • 0 commentsI almost have the axle fully housed. There are still some specifics involved with that, but not very major. I have other plans for the top plate, but as for right now I just have it partially enclosed for testing purposes. Later, after I have it tuned up to par, I will do something different. I think I will be testing out the axle's performance this week!
Axle rebuild
11/17/2023 at 03:24 • 0 commentsAs you can see here, I replaced the 5mm spider axle with an 8mm. On the drive axle, I replaced the one extra long linear bearing with two bearings that I could lock together. This allowed me to prevent the buckling of the axles from the tension of the timing belts. I only put a couple of belts to show what was taking place. before I go further, I may take a little time to choose a brushless motor that would best compliment the project
Take it apart!
11/04/2023 at 15:21 • 0 commentsOnce I started to attach the components, I began to discover the problem areas. First, I realized that the 5mm spider axle could not stand up to the tension from the timing belts. Secondly, I realized that due to mixing different pitches within the differential led to different tensions from having different diameters. I anticipated this result, but it was just one of those things you had to see with your own eyes (trial and error). Thirdly, since designing an axle/differential requires separate shafts, the joining of the shafts were not satisfactory in that the solidity was questionable. With all things considered, different components have been ordered and as soon as I receive them I will put them to work
