The TSOC_GROVEY_ONE allows you to connect thingSoC, Mikrobus, and/or Grove System Modules all at the same time, using the Arduino Development environment, with the the ATMEGA328P processor. This gives you maximum flexiblity for sensor and actuator, selection and reuse.
The thingSoC "Grovey Series" was designed as "Everyday Electronics", a no-frills, low cost, approach to modular embedded product design. thingSoC boards are similar in size to most break-out-boards (BOBs), but feature a standardized stacking pinout, as well as an I2C metadata store (EEPROM) to indicate what peripherals are installed.
- thingSoC Compliant Module
- Mikrobus Compatible Module
- 5V Nominal Power Input
- 5V or 3.3V Operation
- Supports Analog Inputs (ADC)
- Supports Digital Outputs (GPIO)
- Supports Digital Inputs (GPIO)
- Supports I2C Interface
- Supports UART Interface
- Supports SPI Interface
Example Applications
- Weather Sensor BOSCH BME280 Temp, Humidity, Air Pressure
- Methane Sensor MQ-4 Sensor for Methane (CH4)
- Air Quality Sensor MQ-135 Sensor for Harmful Gasses
- Lightning Sensor AS3935 Lighting Strike Detector
- Controlled Relay G6D1AASI Power Relay Control Module
The GROVEY ONE comes with preloaded with the OPTIboot bootloader for Arduino,
but if you prefer to do do bare metal programming, connect an ICSP programmer as shown.
THis will be necessary if you wish to change the default bootloader, or if you brick your device...
Grovey One Pinout Diagram
Pattern Agents
hIOTron
Pure Engineering
namnam
ElectroBoy
