A few people have asked whether or not the Connection Machine miniature has enough room inside for a Raspberry Pi so here are a couple of photos showing the situation.
This is a shot of the two main parts of the body before I glue them together with a RPi inside to show that it does fit:
And here's a look at the rear of the glued-together body with an RPi inside. Those openings on the back are big enough for the Pi to pass inside as long as it is tilted 45 degrees.
Yesterday at the Computer History Museum in Moutain View, CA I looked at a real CM-1 in the collection. Wearing gloves, I was able to look inside. Amazing Design.
is there any room inside to have a Raspberry Pi for doing actual computing and then using the LEDs to display a "result"? Can you post a photo of the inside of the CM? Would you be willing to make a larger CM ? I have a TuringPi 2 board (holds 4 CM4s) that needs a case (airflow required for cooling) and it would be so cool to use a Thinking Machines CM case. Someone has made and posted a Borg Cube case but it's difficult to print all the Borg detail.
Hey, I just posted a log showing the size of the interior of the model with a RPi for scale. Hopefully that will let you determine whether your board can fit inside.
Regarding a larger version, I do sometimes accept commissioned work though my plate is a bit full until January so it wouldn't be a fast process.
@svofski It appears that Hackaday doesn't allow me to add a video here but you can see one on this build thread: https://machines.social/@trevorflowers/111353830269143888
I would love to see the blinkenlights in action. You could just set up the camera like in the static picture, let it run for a minute and optionally tell a few words about the build. It's just it's really nice and intriguing, not unlike its counterpart.
