This project is an effort to design a smartwatch wearable with 10 year battery life on a single charge.
The secondary goals are to learn/advance knowledge low-level design of embedded full stack circuitry and devices for wearables, ultra-low power, maintenance-free, battery powered, wireless, app-driven, and off-the-grid.
Developing a smart watch from scratch would be a great learning experience to advance my knowledge of low-power, self-contained powered devices. Hence, we learn about watches, smart watches and wearables in general by designing one.
This is not a commercial effort. I doubt that we are making anything new per se, however, we are trying to advance the art a lot further than others into the low-power domain.
My background should allow me to filter out the noise and focus on the salient points. My points of view below.
Features:
- Ultra-long life. Years, if not decades. The last watch you'll ever need.
- Maintenance free. Never needed to open and fix anything inside.
- Avoid buttons. Buttons open up the watch to maintenance. Dirt. No moving parts. No bolts, no screws, no mechanical parts. Sealed shut. Control via smartphone? Bluetooth?
- Tough. Bang it on a rock or use it to crush rocks. Metal, steel? Titanium? Aircraft aluminum?
- Under water. Deep ocean depth grade watch.
- Solar / RF powered may be in the future? No battery change.
- Multiple time zones. Automatic time adjust / set up.
- Other features? Compass, altitude, GPS? Atomic clock sync up? Accelerometer? NFC, BLE? What are other watches using?
- Sapphire crystal. Seems other watches are big on sapphire. Diamond? Too brittle? Mineral crystal? Acrylic?
- Anything else?
Work to do... Please check the logs for daily progress!
VALENTINE
Maso
Eric Min
Matias N.
DrYerzinia
I'm working on my own smartwatch project, and it seems we've made a lot of similar design choices. I'm curious how you accomplished waterproofing? Is there a clear place that fits over the display that I can't see? How are you getting a good seal with (what appears to be) 3d printed parts?
