phosphor_gradient_14.py
Update this file on your badge for the simplest way to change the phosphor persistence to 100%. A side effect is the loss of the menu highlighting feature, so you will have to navigate in the blind. A more complete firmware update is pending with a little more free time...
x-python-script -
677.00 bytes -
11/13/2023 at 14:51
Download
Potentiometer knob v5.stl
3D printable knob. PETG or PLA 0.2mm layers.
Standard Tesselated Geometry -
266.10 kB -
11/08/2023 at 05:14
Download
Pot P160 datasheet.pdf
This project uses two of the potentiometers. 10K is a reasonable value, others will work. Cut down about 1/3 to 1/2 of the stem so the knobs fit closer to the frame.
Adobe Portable Document Format -
600.40 kB -
11/08/2023 at 04:56
Preview
HackASketchBodyFinal_0.4n_0.2mm_PLA_MK3_2h0m.gcode
Sliced version of the body for printing in PLA on a Prusa MK3 with 2 colors and support. Near the end of the print you will get prompted to change the filament for the gold lettering layer.
gcode -
2.68 MB -
11/08/2023 at 04:42
Download
HackASketchKnob_0.4n_0.2mm_PLA_MK3_13m.gcode
Sliced version of the knob for printing in PLA on a Prusa MK3. You will need 2 of these.
gcode -
1.49 MB -
11/08/2023 at 04:42
Download
HackASketchBodyFinal.stl
STL of the main body
441.20 kB -
11/08/2023 at 04:41
Download
HackASketchKnob.stl
STL of the knob
248.81 kB -
11/08/2023 at 04:41
Download
