First working prototype
08/20/2014 at 02:50 • 0 commentsFinally I have something that works!
For now I can only connect via usb serial, and use the pheripheral bus, a/d and d/a converters. the I2C bus is protocol is still not implemented, and the FT245 interface needs to be implemented as well. -
PSoC wins
08/07/2014 at 23:21 • 0 commentsI've decided to ditch the CPLD and use the PSoC4 instead. The plan is to have it working both in usb serial mode, or for a faster data stream with the FTDI module.
Thoughts
08/06/2014 at 16:34 • 0 commentsMaybe I should ditch the CPLD and use a PSoC4 instead...
With the CPLD I would have to use a dedicated USB interface IC.
When using the PSoC4 I can use any kind of serial interface, and also the dedicated usb chip. Along with the extra features that can be found in the PSoC4. -
Project start
07/16/2014 at 20:43 • 0 commentsWorking on the first prototype, which will use parts that I currently have in my drawer, nothing fancy yet, just to test the concept. For start I was thinking about using the FT245 USB interface and a Xilix CPLD for control.
