Adding mounting holes V1.1
02/13/2024 at 05:00 • 0 commentsThe newer version of the PPSTrigger board now features half-cut mounting holes. This will fit your standard M2 screw or bolt. No more gluing your circuit to your 3D-printed enclosure.
The new board also features a new LDO that has better ESD protection than the previous selection.
Video: Product introduction and how-to
01/05/2024 at 23:55 • 0 commentsThank you for all of the support we have in Hackaday and also on Reddit. We are working on getting the unit back in stock as well as creating a video that would cover:
- Product introduction
- Explain the voltage selection decision tree of the device, PPS vs fixed voltage
- Explain e-mark cable 5A vs non e-mark 3A and how it impacts power output
- Example of the over-current draw on the circuit
- Example of using non-PD power brick
- How to mount the board on your 3D design
Please comment below if there is anything you would like us to cover.
