Ai Ham Radio Responder
AI clone of yourself as a ham amateur
Public Chat
• An AI clone of yourself as a ham amateur
• Voice cloning is possible to use your voice instead of Ai voice.
• Ai listens for your call when you’re away and answers them in a friendly QSO.
• Vision is possible to ask if it’s cloudy? signal reading, etc.….
• The QSO is saved in a text file. Can Retrieve later to read out or read or search on a html page.
• Ai check for answers from predefined form you have fill info like location, name, etc.
• Acts as an answering machine that answers for you.
• Have a conversation with it.
• Can listen to calls in QSO and pass msg to an operator.
• Could host a net by itself.
• Can act as lots of things, a beacon, announce weather warnings.
• From the ham shack see online the Realtime transcript of your contact with the ai ham happen
• Ham operator can text in the program and AI will transmit msg
ZS6WDL - Jaques wrote 04/24/2024 at 14:49 • point
Capture Audio from the Two-Way Radio:
Use a sound card interface to capture analog audio from the two-way radio.
You can achieve this using libraries like sounddevice (which unfortunately isn’t available in this environment, but you can install it locally).
Process Captured Audio:
Implement audio processing to improve quality (e.g., noise reduction, filtering).
You can use existing audio processing libraries or write custom code.
Convert Audio to Text:
Use a speech-to-text library or API to convert the captured audio to text.
For demonstration purposes, let’s assume the detected text is “This is a test sentence.”
Check for AI Callsign:
Compare the detected text with the AI’s callsign (e.g., “AI123”).
If the callsign is present, proceed to generate an answer.
Generate an Answer:
Based on the detected text, create an appropriate response (e.g., “Yes, I’m here. How can I assist you?”).
You can use predefined answers or implement more complex logic.
Convert Answer to Audio:
Use a text-to-speech library or API to generate audio from the answer text.
For demonstration, we’ll simulate this with random noise (replace with actual TTS output).
Inject Answer Audio into the Two-Way Radio:
Simulate injecting the answer audio into the two-way radio (you’ll need to replace this with your actual hardware interface).
Ensure that the audio levels match the radio’s input requirements.
Run the Program on Windows:
Write your program in a language like Python, C++, or C#.
Ensure it runs on Windows by handling any platform-specific dependencies.
