CRTFORPX.INF.txtInfo for a similar, but homegrown project, intended for an IBM monochrome monitor. The original file is called ''crtforpx.lbr'' and was found at http://cerealport.homeip.net/cereal/px8/. The file was corrupt or made with a unknown version of the LBR compression program, so the included drivers are lost.plain - 14.23 kB - 05/11/2024 at 18:51 |
reUD80V0.10-signalScreenshots.zipSome screenshots of the scope screen of signals of a properly working Re-UD-80. See the log "Debugging a problem board".Zip Archive - 201.52 kB - 04/01/2024 at 11:37 |
re-UD-80_Case.zipNew set of 3D printer files. Improved button hole size and location, added a front panel without RGB-DIN hole.Zip Archive - 199.99 kB - 04/01/2024 at 10:51 |
oval80replicaV0.10_bom.zipThe BOM with remarks from brijohn@forum.vcfed.org.Thanks! Zip Archive - 1.81 kB - 03/30/2024 at 16:35 |
oval80replicaV0.10.connectors.pdfExternal connector and jumper info.Adobe Portable Document Format - 1.15 MB - 03/30/2024 at 16:33 |
oval80replica0.10.kicad.zipKiCAD 6.0 design files, including some custom libraries for vintage symbols and footprints.Zip Archive - 336.67 kB - 03/02/2024 at 17:24 |
ud80_rom7.11composite.zipPatched 7.11A ROM to generate composite sync, making it compatible with the RE-UD-80 v0.10 board. Includes a dissassembly with some annotations used to find the proper configuration bits.Zip Archive - 48.58 kB - 03/02/2024 at 07:29 |
UD80_rom5_21-low.lstPartial disassembly of the 5.21E ROM.lst - 303.17 kB - 02/24/2024 at 20:33 |
reud80OpenCase.jpgThe case is designed to fit around the board with small tolerances. No internal mounting is required when the case is closed.JPEG Image - 136.46 kB - 02/24/2024 at 11:43 |
reUD80box1.zip3D printer files, object files for top and bottom case, front and back panels. This case fits the version 0.10 PCB exactly.Zip Archive - 172.31 kB - 02/23/2024 at 20:48 |
oval80replicaV0.10.csvComponent list as produced by KiCADComma-Separated Values - 2.54 kB - 01/10/2024 at 09:50 |
oval80replicaV0.10.kicad_sch.pdfThe final 0.10 schemaAdobe Portable Document Format - 188.66 kB - 01/10/2024 at 09:46 |
oval80replicaV0.10.kicad_prod.zipThe file set as send to the PCB-manufacturerZip Archive - 85.27 kB - 01/10/2024 at 09:40 |
ovalUD-80-replicaV0.10.jpgThe prototype board that actual worked after fixing embarrassingly mistakes on the back side. The board is a modified version 0.8.JPEG Image - 278.82 kB - 12/30/2023 at 21:12 |
UD80_ROMS.zipOval ROMs for the UD-80 and DS-8. The 5.21E ROM contains drivers for the PX-8, the 7.11A drivers for the PX-4. The DS-8 driver is an other Oval device allowing for both a printer and a UD-80 on the same RS-232c port.Zip Archive - 18.43 kB - 12/30/2023 at 21:08 |
ud80_ec198603.pdfA review of the original UD-80 in the Epson Connection magazine of March 1986Adobe Portable Document Format - 948.08 kB - 12/23/2023 at 21:17 |
