sensor_housing_v2.stl
attach RGB sensor module and seal carefully with black silicone to stop light leaking in via the sides
Standard Tesselated Geometry -
71.66 kB -
03/17/2026 at 08:13
Download
vee_channel_vibrator_mount_large_v2.stl
larger mount to take a 280 motor - PRINT 2x AND GLUE THEM BACK-TO-BACK
104.96 kB -
07/06/2025 at 13:40
Download
controller_case-Rear.stl
Case (rear) for the screen/controller
727.43 kB -
07/06/2025 at 13:39
Download
controller_case-Front.stl
Case (front) for the screen/controller
765.32 kB -
07/06/2025 at 13:39
Download
drum_feeder_scoop_v3.stl
latest (smaller) scoop design - PRINT 6 - 12x
4.57 kB -
07/06/2025 at 13:38
Download
PDQ_ILI9341_config.h
header file to accompany Lego_display.ino
h -
2.40 kB -
07/06/2025 at 13:38
Download
Lego_display.ino
Arduino Nano C source for the microcontroller that runs the touchscreen
ino -
16.77 kB -
07/06/2025 at 13:38
Download
Lego.ino
Arduino Nano C source for the microcontroller on the machine
ino -
13.72 kB -
07/06/2025 at 13:37
Download
off_centre_mass.stl
Tap holes to M3 and add screws as required to create an unbalanced mass - attach to motor spindle.
953.79 kB -
06/17/2024 at 19:51
Download
Vee_channel_end_scoop.stl
810.63 kB -
06/17/2024 at 19:51
Download
tube_spindle_mount.stl
314.14 kB -
06/17/2024 at 19:51
Download
vibe_feeder_end_bracket.stl
For fixing vibe feeder to alu profile - PRINT 2x
492.07 kB -
06/17/2024 at 19:51
Download
65mm_pipe_flange_v2.stl
382.99 kB -
06/17/2024 at 19:51
Download
photodiode_tube.stl
helps collimate the beam entering the photodiode sensor
82.60 kB -
06/17/2024 at 19:51
Download
vee_channel_rigid_mount.stl
to secure the short section of (non-vibrating) Vee channel to 20mm alu profile.
47.15 kB -
06/17/2024 at 19:51
Download
40mm_pipe_clamp.stl
for the funnel assembly
135.04 kB -
06/17/2024 at 19:51
Download
roller_bracket.stl
to support the rollers - PRINT 6x
217.86 kB -
06/17/2024 at 19:51
Download
motor_mount_upper.stl
fit to NEMA stepper motor
198.91 kB -
06/17/2024 at 19:51
Download
Vee_channel_hood.stl
helps keep light out of the sensor - PRINT 2x or more if required.
3.01 kB -
06/17/2024 at 19:51
Download
motor_mount_lower.stl
85.82 kB -
06/17/2024 at 19:51
Download
