Hello Guys, Once again I have made a microcontroller Development board but this time we are using INTEL 8051. Yeah! I know it is pretty old and it is the first microcontroller I had started with. It was the 1st microcontroller of INTEL, released back in 1980, and the computer era started from there. This is very popular and even nowadays there are few applications like calculators, Automotive applications which are running on it. In the 1980's there was no concept of flash ROM and even at that time this MCU came with Harvard architecture in which code and data memory are separated from each other.
![](https://cdn.hackaday.io/images/7680581705062484128.png)
But nowadays as microelectronics grow some custom solutions are available which are utilizing the same die of microcontroller as a brain but with added peripherals like onboard flash, Extra RAM, 2 cores on a die, higher crystal compatible circuitry, onboard programming control and which may give this higher performance. INTEL is not manufacturing this microcontroller now, but there are some 3rd parties which are making custom solutions as per specified applications. The original microcontroller is rarely available in the market, because the production was stopped many years ago.
This project is sponsored by NextPCB, NextPCB is really very good in PCB manufacturing in competitive pricing delivering worldwide. First 5 pcs of assembly are free and the shipping fee is also very less. You can give a try to NextPCB at the end of this article and find the section of PCB review to find out the quality. The first 5 pcs assembly boards are free.
Original 8051 Features:
- 40 pins DIP (dual inline package),
- 4KB of ROM storage
- 128 bytes of RAM storage
- 2 16-bit timers
- Low-power Idle and Power-down Modes
- It consists of four parallel 8-bit ports (32 Programmable I/O Lines)
- An on-chip crystal oscillator having crystal frequency of 12 MHz
80s52 Custom 8051 microcontroller:
- 8KB of In-System Programmable (ISP) Flash Memory
- 4.0V to 5.5V Operating Range
- Fully Static Operation: 0 Hz to 33 MHz
- 256 x 8-bit Internal RAM
- 32 Programmable I/O Lines
- 3 16-bit Timer/Counters
- Eight Interrupt Sources
- Full Duplex UART Serial Channel
- Interrupt Recovery from Power-down Mode
- Watchdog Timer
- Dual Data Pointer
As you might see, the performance of a microcontroller depends on architecture, clock rates and Design logic. 80s52 has higher performance and better features than Original microcontroller with 8KB onboard Flash as program memory. Here is the link to the full datasheet, explore the datasheet for operation related knowledge.
Components Required:
![](https://cdn.hackaday.io/images/8781361705062514997.png)
- 80S52 microcontroller (8051)
- 40 PIN IC Socket
- 0603 LEDs
- 1K and 10K resistor
- 10uf, 100nf, 33pf capacitors
- 12MHz crystal oscillator
- USB type C
- Pin Headers
- AMS1117 5V Regulator
- 12V Jack
- Reset Switch
Development board:
![](https://cdn.hackaday.io/images/4990061705062547973.png)
We need an activation circuit to program this microcontroller, which contains a reset circuit, programming headers, crystal oscillator and some loading capacitors. That is known as minimal system required for a microcontroller, still there are some issues remain which has to be resolved like power supply, headers for I/O and programming pins. So, I designed a development board rather than making a minimal system. Which allows to directly connect the peripheral on I/O ports of the microcontroller. I took inspiration from Arduino UNO and designed a PCB with all the controls on it, the programming headers are placed on one header, and all the 4 ports have dual headers. I also designed the power section with some capacitor, Dc jack and linear voltage regulator on the same board.
Circuit diagram:
![](https://cdn.hackaday.io/images/6457681705062564093.png)
8051 required a pull up resistor on reset pin which is used to perform all the operation and this pin never kept floating, and a tactile switch is added to pull down the reset pin to Reset the overall microcontroller and to resume the operation from beginning. I am using a 12MHz capacitor with 33pF loading capacitors as mentioned in the datasheet, the...
Hello, I works on 8051 architecture project under Arduino. The complet projet is disponible on sourceforge. It allows compiling and burning a C ino compatible program under Arduino IDE into 8951, 8951 and family (STC89, STC15, STC32...), see this projet. It exist too a complete board with Arduino Uno Pinout compatible and based on 89C51 or 89C52.... Self-Programming.... Like Arduino Uno, etc.... https://sourceforge.net/projects/stc89/
