1Download and install Arduino software
It required for install and edit the code onto the arduino board.
2Go to the site below to find the box shape that fit for our project.
https://www.festi.info/boxes.py/BasedBox
Also we need to adjust the dimension according to what we need and laser cut it.
3Use Fusion360 for the 3D printed material
We used it to design our thunderbolt with a hollow in the thunder shape.
4Use sound sensor, temperature and humidity sensor
Gather all those sensors for our project so that we can have it to help create interactive feedback.
5Program Arduino Uno
We used to upload the code for all the sensors.
6Upload the code to sound sensor
We linked the sound sensor and the LED strip whenever there sound it lit up. (The code is in the file)
7Upload the code to temperature and humidity sensor.
Whenever there is a weather temperature change the color of the LED neopixel will change accordingly.
8Print the case
Use the box file that we uploaded in the file folder to create the case for our project.
9Print the thunderbolt
Use our thunder STL file to print the shape with the 0.5mm thickness.
10Use the breadboard
We only use a small part of it which is the the side of the small breadboard. (So that it fit
better inside the case)
