Pomelo: Gamma Spectroscopy Module
A complete low-power gamma ray spectrometer that can be used by itself or integrated into other projects
Pomelo is a radiation detector for hobby-level gamma spectroscopy. I’m designing it according to the following requirements:
- Low cost. Target is below 150 Eur in components
- Commercial off-the-shelf scintillator and SiPM
- Low power. Ideally ~5mA while data taking
- USB connectivity (CDC for dumping data to a terminal)
- UART for interfacing with an external MCU
- Energy range: 50 keV – 3 MeV
- Onboard histogramming and run control
- List-mode data option
- Temperature compensation
- Coincidence measurements with two devices using dedicated hardware handshaking
- Software configurable energy threshold
Pomelo will be launching on Crowd Supply https://www.crowdsupply.com/pomelo-instrumentation/pomelo
This project is inspired by three awesome projects, two of them being open-source:
All-In-One Gamma-Ray Spectrometer https://hackaday.io/project/185211-all-in-one-gamma-ray-spectrometer
Cosmic Pi https://github.com/CosmicPi
Radiacode https://www.radiaco
Complete gamma spectroscopy module ready to be connected either to a laptop or an embedded system. It measures less than 130mm x 40mm x 30mm
This contains everything that’s needed for gamma spectroscopy and nothing more. It has the detector assembly (Pomelo Physics) with scintillator and silicon photomultiplier, as well as the accompanying electronics (Pomelo Core) with bias supply, analog front end, and digital electronics.
Its USB and UART connectivity allow it to interface to lots of things, like a laptop, an Arduino, or a Raspberry Pi. It integrates a level shifter on the UART lines so it can talk to both 3.3V as well as 5V systems. I have used it during development to perform measurements with radioactive sources or cosmic muons:
I made an Arduino-compatible board that contains supporting circuitry to make a complete hand-held instrument based on the Pomelo Core and Physics. It has buttons and a screen, battery, and lots of wireless connectivity:
I'm also using Pomelo to experiment with visualizing gamma spectra in a more intuitive way, shown as colors on an LED strip:
Pomelo Physics
Pomelo Physics is the detector assembly, containing:
Pomelo Core
Pomelo Core contains all the associated electronics:
  • Digitally controlled SiPM bias supply ~32V - ~48V
  • Digitally controlled threshold
  • Low power analog front-end
  • ARM Cortex-M0+ microcontroller, Microchip ATSAML21G18B
  • UART connectivity with integrated level shifter
  • 10 unused GPIO pins for further expansion
Performance
Spectra for various radioactive sources taken with Pomelo
The energy resolutions at different energies are:
  • <30% @ 59.5 keV
  • <11% @ 511 keV
  • <7% above 1274.5 keV
This is the original description when I started the project in January 2024
This is very much a work in progress and most of the requirements are not satisfied yet. But thanks to excellent documentation done by NuclearPhoenix on the All-In-One Gamma-Ray Spectrometer and the Cosmic Pi project I have a proof of concept working.
Pomelo hardware and gamma spectra taken with Cs137 and Na22
Current version of the hardware includes:
  • 4mm x 4mm x 10mm GAGG(Ce) scintillator crystal with light reflector and 3D printed “dark” box
  • 4mm x 4mm Broadcom AFBR-S4N44P014M Silicon photomultiplier (SiPM) with optical grease coupling to scintillator
  • MAX1932 SiPM bias supply
  • Shaper to decrease bandwidth of SiPM pulses
  • Peak detector circuit
  • ATSAML21E18B MCU that performs triggering, pulse height measurement, and peak detector reset
Energy resolution is 14.3% @ 662 keV and 12.4% @ 1274.5 keV.
Architecture
  • Education & Outreach
    mihai.cuciuc08/04/2026 at 05:06 0 comments
    For the past year I've been busy improving the hardware but also running a small-ish educational project funded by the Romanian Ministry of Education and Research. I'm going to high-schools to discuss ionizing radiation, and to take measurements with the students in the classroom using this hardware. It's been a great opportunity to get feedback on the hardware and to try to get students interested in the many topics of radiation and its measurement.
    One of the deliverables for this project is a series of YouTube videos. While I'm definitely not made to be on camera, I had a blast making them! I'll post them here. Any feedback is extremely welcome!
  • Pomelo on Crowd Supply
    mihai.cuciuc01/30/2025 at 05:33 0 comments
    Pomelo will be launching on Crowd Supply where you can subscribe to be notified when it's ready: https://www.crowdsupply.com/pomelo-instrumentation/pomelo
    The business side of things is a very new topic to me, and it's full of challenges. But what I did not expect was that, since I'm super passionate about building this detector and sharing it with the community, I seem to enjoy most of these challenges.
  • Theremino MCA
    mihai.cuciuc08/02/2024 at 21:16 0 comments
    Pomelo is all about interfacing with as many things as possible. Theremino MCA is a popular open-source gamma spectroscopy software designed to work with DIY detectors. It relies on the PC’s sound card for digitizing pulses in order to build a spectrum.
    Pomelo Core makes internal analog signals available on a pin header, mostly for debugging. Among these there is a low-pass filtered version of the SiPM output. Unfortunately, it’s still a bit too fast to be properly digitized by a PC sound card and while it does work, the results are a bit wonky. But if we slow it down a bit more using an RC low-pass filter, it becomes just right. I used 10 kOhm and 10 nF.
    To get a feel for how well the pulse amplitudes match between the Pomelo Core output and the signal that is read by the sound card I grabbed some pulses both with a Saleae logic analyzer and with Audacity and manually aligned the time scales to look at the same pulses.
    Pulses from a Th-232 source at different stages in the analog chain. The time scale is manually aligned to look at the same pulses in both Saleae Logic and Audacity.
    Same plot as above but zoomed in to see the shapes of individual pulses
    The sound card is detecting pulses as being negative, despite the Pomelo output being positive. I inverted the waveform in Audacity to make things easier to see.
    One thing to notice is that the RC filtered signal rides on a DC baseline of ~2.5V. This is due to the PC’s sound card providing bias for the microphone -- it’s not a huge problem for Pomelo, as its output is fed directly from a stiff source, an op-amp’s output. The 10 kOhm resistor nicely isolates these two.
    The spectrum of a Th-232 source looks very good both in the Theremino MCA software, as well as exported and displayed alongside the spectrum recorded by Pomelo Core.
    Th-232 spectrum and individual pulse in the Theremino MCA software
    Spectra taken with both Pomelo Core as well as with Theremino MCA, with uncalibrated x axes scaled to cover the same energy range
  • Pomelo core in coincidence mode
    mihai.cuciuc07/15/2024 at 04:18 0 comments
    I used a pair of modules are run in coincidence mode to detect and measure cosmic muons.
  • Pomelo Core new use case
    mihai.cuciuc06/21/2024 at 04:28 0 comments
    I added a new project describing an experiment that uses Pomelo to measure gamma attenuation in aluminum. The result is surprisingly close to the literature value.
  • Updated scintillator and wide range energy linearity
    mihai.cuciuc06/17/2024 at 16:15 0 comments
    Pomelo sales rep showing off the latest prototype sporting a 10mm x 10mm x 20mm CsI(Tl) crystal
    I designed the device dimensions with a 2cc (10mm x 10mm x 20mm) CsI(Tl) scintillator in mind, but only had 3cc ones to test with. It’s why the detector element extended beyond the device’s edge, but now that the 2cc crystals arrived, I can share the final design and some preliminary performance plots.
    The scintillator is not yet potted in silicone, which does decrease light output a little (and thus worsens resolution). I took spectra with several lab sources and computed the resolutions for every gamma line and checked the detector linearity.
    Spectra for Am-241, Na-22, Cs-137, Mn-54, Co-60, and Th-232 on the same plot in logarithmic scale. Energy resolutions for each energy shown in the last column
    Detector linearity plot. There is a small quadratic term that is typical of SiPMs
  • Pomelo Core use cases
    mihai.cuciuc06/01/2024 at 09:44 0 comments
    I updated the project description to include use cases for the Pomelo. One is a complete hand-held instrument with battery, user interface, and lots of connectivity, and others are physics experiments that are enabled by the Pomelo:
  • Pomelo Core v1
    mihai.cuciuc05/23/2024 at 04:54 0 comments
    This contains all the functionality to do gamma spectroscopy and nothing more
    I'm planning on producing something that looks more similar to other gamma detectors, like the excellent products that are already out there: the Radiacode, the Kromek Sigma25, or the CapeScint CsI-MacroPixel-MCA. To shift towards that I merged the digital and analog electronics into a single PCB, removing the battery and charging circuit, as these are not core to the functionality of the detector. The detector now consists of two parts:
    Pomelo Physics:
    • CsI(Tl) scintillator, 3cm^3
    • Silicon photomultiplier
    • 3D printed dark box to house scintillator and keep stray light away from SiPM
    • Temperature sensor
    Pomelo Core:
    • Microchip SAML21 (ARM Cortex-M0+) microcontroller
    • USB connectivity
    Pomelo Physics. Scintillator and SiPM detachable module
    Back of Pomelo Core PCB
  • Scintillator potting
    mihai.cuciuc05/13/2024 at 04:48 0 comments
    CsI(Tl) scintillators are slightly hygroscopic – they absorb some moisture and this affects their crystal structure, worsening their performances. However, the magnitude of this worsening is very small as shown by this paper and this paper.
    In any case, my plan is to limit the amount of moisture that can reach the scintillator by adding silicone in between the Teflon-wrapped scintillator and the 3D printed detector case that serves as a dark box. Using a somewhat rubbery silicone will also work to provide some cozy mechanical support for the scintillator. The resulting internal structure of the detector assembly should look like the following diagram:
    Detector assembly structure. The scintillator is attached to the SiPM (not shown) that is soldered to the PCB. I plan on filling the gap between scintillator and dark box with silicone
    Room-temperature vulcanizing silicone curing test
    As I’m using a one-component RTV silicone I wanted to make sure that curing still happens inside the 3D printed box, as the exposure to outside air is quite limited in that case. To test this I printed a fake “scintillator” block that I wrapped in Teflon and I made a few test runs that I could then break and look inside for how the curing went.
    Test pieces for testing potting and curing. No expensive components (SiPM or CsI(Tl) crystals) were hurt in these tests
    Loading some silicone into the dark box and then squishing the assembly in
    Having assembled these units I let them cure for ~1 week. I then broke a few and extracted the plastic fake “scintillator” and its Teflon wrapping to find this very nicely cured shell around the scintillator block.
    Broken test assembly. The silicone cured nicely everywhere, but I did not manage to get it completely centred
    One thing I did not consider is that the fake "scintillator" I 3D printed with ~30% infill was full of air. While it was covered in Teflon, I'm not sure this was an air-tight barrier, so some of the curing might have happened because of that empty space. In any case I assume that it will still cure just through the shell, even if it will take longer.
    With this test successful I went on to pot an actual scintillator and see how this affects its performance.
    Detector performance after curing
    I potted a real detector and took Na-22 spectra before and afterwards to obtain the following spectra.
    Na-22 spectrum and resolution for the 511 keV gamma line before silicone potting (red) and after potting (blue)
    The peaks are shifted a little to the left after potting, so the pulse height is somewhat lower, suggesting that light collection is not as good as before potting. This is also indicated by the slight worsening of the energy resolution. While there is some loss in light that gets collected on the SiPM, the added resilience of the detector assembly is worth it.
  • Digital temperature compensation
    mihai.cuciuc05/09/2024 at 05:13 0 comments
    The gain of silicon photomultipliers (SiPMs) increases with applied voltage and decreases with temperature. Hamamatsu has an informative write-up on this topic.
    This presents an opportunity to compensate for temperature changes by tuning the bias voltage, with some circuits doing this directly in hardware, by having a thermistor in the voltage feedback loop of the bias supply. An example of this is in Figure 8 in the MAX1932 datasheet.
    I decided to go with a digital temperature sensor and tweak the bias voltage in firmware. The temperature sensor is placed directly underneath the SiPM on the detector PCB to get a reading as close as possible to the sensor.
    A TMP126 chip in the middle of the detector PCB provides very accurate temperature readings. The SiPM is directly underneath it, on the other side of the PCB.
    I ran a few tests to see how temperature and bias voltage influence the spectra from a Na-22 source, with the following animated results.
    Increasing temperature of the SiPM decreases its gain, so the gamma peaks shift to lower values in the spectrum. This can really mess up the long-term stability of the detector and make gamma peaks disappear into blobs. Temperature is in degrees Celsius.
    Higher bias voltage increases the SiPM gain.
    From this data I derived a voltage compensation coefficient and managed to keep the gain fairly stable, with a loop that runs every 5 seconds and updates the bias voltage. While it’s not great, it’s much better than without it.
    Relative gain shift with fixed bias voltage (orange) and with a varying bias voltage calculated from the temperature value.
    The difference that this makes is in keeping an overall better energy resolution for the system at varying temperatures.
    Left plot has data taken between 29 and 40 degrees Celsius, without temperature compensation loop running. Plot on the right is taken between 24 and 40 degrees Celsius, but with the temperature compensation enabled and results in a better energy resolution.
View all 20 project logs
Residual Entropy wrote 08/09/2024 at 18:41 point
I've been looking for a way to do gamma spectroscopy semi-affordably and this is exactly what i was looking for, this is awesome!!
[deleted]
mihai.cuciuc wrote 07/14/2024 at 16:33 point
Hi, Dylan,
Yup, that's the plan -- in its entirety, actually. I plan on selling them and making the firmware and schematics available. Not the PCB layout though, as by the time you start modifying that you're better off redoing the whole thing anyway.
It will take me a while to start selling them -- I'm reasonably good at engineering, not at the business side of things. But if you're way too eager to get one, PM me.
Dan Maloney wrote 06/04/2024 at 23:39 point
Fantastic project, love the lesson in scintillation counting. Wrote this up for the blog, should publish soon. Great work!
peter jansen wrote 04/17/2024 at 05:01 point
Super interesting!  How small do you think you could ultimately make the sensor and accompanying electronics?
mihai.cuciuc wrote 04/17/2024 at 05:04 point
Thanks! I'm aiming to fit everything on a 5cm x 10cm PCB, with the height given by the detector laid on its side, so about 2.5cm.
peter jansen wrote 04/17/2024 at 23:34 point
Since the Radiation Watch Type 5 has been retired, I was hoping you'd say something along it's size so that it could be a close mechanical replacement :) ( https://www.sparkfun.com/products/retired/14209 ).  I've tried to get it to do similar things to what you're doing, by measuring pulse width instead of height/AOC (only a correlate of energy) -- it'd be wonderful to have a proper solution in a small form factor to put on hand-held devices!
mihai.cuciuc wrote 04/18/2024 at 05:39 point
Oooh, I see -- the Radiation Watch Type 5 was indeed pretty cool -- I'll think about what could be done in similar size constraints.
Meanwhile, I suggest you take a look at the Semeatech Mini Gamma Sensor ( https://semeatech.com/Products/Radiation%20Detection/Mini%20Gamma%20Sensor.html ). It's super small, draws very little power, and has decent performance above 300 keV. I played around with them a little so let me know if you want some spectra.
Mitchell de Vries wrote 02/14/2024 at 22:46 point
Those spectra are looking nice and clean, you're inspiring me to restart my radiation detecting projects! Did you have much issue sourcing suitable calibration sources? Also, I'm guessing you'll be implementing calibration?
mihai.cuciuc wrote 02/15/2024 at 06:14 point
Thanks! I'm glad to hear my toying around is inspiring!
I have a gamma spectroscopy lab at work, so we have quite a few radioactive sources I could use for calibration. Yup, right now I do energy calibration offline, and it's pretty linear, with a very small quadratic term that is fairly common with SiPMs. The plan is to store calibration constants on the device.
But I also had good success calibrating it without lab sources, using commercial Th-232 welding rods (WTh20), a smoke detector Am-241 source (but they don't sell those in the EU any more), and K-40 from salt substitute. This last one requires some patience though :)
Muth wrote 01/18/2024 at 15:01 point
This is highly interesting ! May I ask if you have advises to source scintillators and SiPM ?
Thanks !
mihai.cuciuc wrote 01/19/2024 at 06:02 point
Thanks!
Sure, I got the SiPM from Farnell: https://ro.farnell.com/broadcom/afbr-s4n44p014m/silicon-photomultiplier-1-ch-420nm/dp/4236230
I chose them because they're fairly inexpensive and seem to be quite new (i.e. not going to be EoL soon).
As for the scintillators, I have them from OST-Photonics: https://www.ost-photonics.com/product-category/scintillation-crystal-2/
Muth wrote 01/23/2024 at 15:38 point
Thanks you very much !
