USB-TTL using CH551G
02/24/2026 at 05:55 • 0 commentsSince there is only one Chip used in the DIP40 board, there are lots of empty space. So there is a USB-TTL circuit added using CH551G.
With the integrated USB-TTL, we can connect the Single Chip Computer to a PC using VCC, GND, D+ and D- of the USB port. We do not need a external USB-TTL circuit.
Integrated USB-TTL circuit using CH551G - SOP16 ![]()
Integrated USB-TTL circuit with microUSB connector Just using VCC, GND, D+ and D- we can connect the Single Chip Computer to a PC serial terminal via USB port. The power for Single Chip Computer and USB-TTL circuit drawn from USB port. No external power supply required.
mit41301
