1Solder components to PCB
Solder all four components to the PCB: Power supply chip, inductor and the two ceramic caps.
2Remove U7
Remove the original linear regulator from the GBC mainboard.
3Mount replacement part
Solder the replacement part from step 1) to the two outer-most pads of the 3 pads on the bottom. The middle pad on the bottom and the two pads on top will not be soldered.
4Add power cable to the replacement
Solder a wire to the power switch pad labeled "C" and connect it to the pad on your replacement part.
