AnyFlasher PCB v1.0.0 test completed
03/31/2024 at 13:28 • 0 commentsTested the first version of the board.
Found a few errors:
1. Missed route
2. Activation of the MUX without an address leads to a short circuit of the zero pin
3. The voltage drop on the Darlington array is too highConclusions: soldering the board to the end does not make sense, it is necessary to fix the PCB
PCBs
03/26/2024 at 11:06 • 0 commentsThe printed circuit boards have arrived. I have already started phased assembly and testing.
