Design For Manufacture, They Told Us...
A project log for PiTrac - The DIY Golf Launch Monitor
Launch monitor using low-cost Raspberry pi and camera hardware to determine ball launch speed, angles and spin
james-pilgrimJames Pilgrim 10/03/2024 at 15:210 Comments
Apparently the best way to learn what designs DO NOT work reliably is just to make every 3D printing mistake in the book as we go. Which we are doing quite well.  For example, the image below shows the result of printing the enclosure design with a different filament type (PLA in this case) to see how it would work.  The result indicates insufficient print-bed adhesion as well as (possibly) over-aggressive cooling tuning resulting in pull-away and part warping.  New design will have a more filled-in base layer.
Things always look wonderful in the CAD software, but then you hit print and ... <doh> ...
