Purchase worldwide V2.2: Tindie, Lectronz, Elecrow
Reference case design Fusion360
Example application
Driving high power LED array directly with fan and heatsink for cooling.
Specification
USB-C Trigger for fixed PDOs, or PPS with Constant Voltage or Constant Current mode. The operating trigger range is 3.3V-21V @ 3A max.
Improvement from version 1
- Constant current mode
- Better overall ESD protection
- Output flyback diode protection
- Reverse current protection
How to use the board
- Default (no jumper): CV mode. Max voltage is set by the potentiometer. Maximum current rated for cable/power supply.
- 1A jumper: CC mode at 1A. Max voltage is set by the potentiometer.
- 1.5A jumper: CC mode at 1.5A. Max voltage is set by the potentiometer.
- 2A jumper: CC mode at 2A. Max voltage is set by the potentiometer.
- 2.5A jumper: CC mode at 2.5A. Max voltage is set by the potentiometer.
- 3A jumper: CC mode at 3A. Max voltage is set by the potentiometer.
- 4A jumper: No application
*Fixed PDO: Flat voltage level like 5V, 9V, 12V, 15V, and 20V
*CC: Constant Current Mode
*CV: Constant Voltage Mode
Important note
Not all USB-C power supplies support Programmable Power Supply (PPS). and not all PPS power supplies support CC mode. Through our small sample size that includes powerbank/charger from Anker, Ugreen, and Baseus, here is our recommendation for getting Constant Current mode out of the box:
- UGREEN 100W - PPS 3.3 - 21.0 @ 3A
- UGREEN 140W - PPS 3.3 - 21.0 @ 5A
- AOHI Magcube 140W - PPS 3.3 - 21.0 @ 5A (No longer recommend)
- GKUTW HX65P3 65W - PPS 3.3 - 21 @ 3A
- Anker 737 (GaN Prime 120W) - PPS 3.3 - 11.0 @ 3A
- Anker 737 Power Bank - PPS 3.3 - 21.0 @ 5A
- Anker PowerHouse 521 - PPS 3.3 - 11.0 @ 3A
- ..... too many. Mostly anything that says "PPS" would work
Our lab recommends using the UGREEN Nexode charger. There is another Ugreen Nexode charger that our lab has not tested. Your feedback on that charger will be appreciated!
In Constant Voltage, the trigger board will try to utilize the PPS profile if it exists before using the standard fixed profile to provide the requested voltage from the potentiometer.
Programmable Power Supply (PPS) in PD3.0/PD3.1
Detail specifications for PPS mode can be found at USB Power Delivery 2019 Presentation
Even though the downstream device can request a 50mA current limit step in PPS mode, the lowest settable current limit is 1A with ± 100mA accuracy. This value is called iPpsCLMin in the specification. When the load is attached, and the current exceeds the limit value, the charger should lower the voltage until the current reaches the target limit. If the voltage is lower to 3.3V and the current is still exceeded, the supply will "give up" regulation and maintain the lowest voltage at 3.3V while outputing whatever current is being drawn.
Reverse current protection is not mentioned in the specification. Reverse current can happen when your source voltage is lower than your device voltage, normally your battery (Vsouce < Vbatt), thus allowing current to flow from your battery to your charger. Anker has confirmed that their IQ standard supports reverse current protection, but all manufacturers do not guarantee implementation.
For this, PPSTrigger has also implemented reverse current protection, regardless of your charger implementation. Current only starts to flow when your Vsource > Vbatt.
Dimension
Reference Case Design
High power LED drive directly from USB-C without series resistor
CentyLab
MagicWolfi
Shuo Cao
Hello! I've been using the PPSTrigger V2 and I really like the small form factor. However, it doesn't seem to be handling the multiple PPS profiles my charger supports. It seems to always pick the first PPS profile and if the POT exceeds the voltage in the profile, it stops sending requests.
I've captured the PD communication and analyzed it using PulseView.
Capabilities: USB PD: Payloads: [1] [Fixed] 5V 3A (15W) [unconstrained] [dual_role_data]
Capabilities: USB PD: Payloads: [2] [Fixed] 9V 3A (27W)
Capabilities: USB PD: Payloads: [3] [Fixed] 15V 3A (45W)
Capabilities: USB PD: Payloads: [4] [Fixed] 20V 2.25A (45W)
Capabilities: USB PD: Payloads: [5] [Programmable|PPS] 3.3/11V 3A [limited]
Capabilities: USB PD: Payloads: [6] [Programmable|PPS] 3.3/16V 3A [limited]
Capabilities: USB PD: Payloads: [7] [Programmable|PPS] 3.3/21V 2.25A [limited]
Request: USB PD: Payloads: [1] (PDO #5: Programmable|PPS 3.3/11V) 9.26V 1A [comm_cap] [no_suspend]
I've tried several things yielding similar results. If I start the PPSTrigger V2 board with the POT above 11V at turn on, the PPSTrig doesn't request anything beyond profile 1 fixed 5V. If I start below 11V, the PPSTrig will request the voltage until I go above 11V and then stop making requests. Then once I bring it below 11V again the requests continue. I tried different CC settings on the board: 1A, 2A, CV all with the same results. I also tried a second PPSTrigger V2 board I have with the same behavior.
The charger in question is the Anker 313 Charger (Ace, 45W). Any thoughts on this? Thanks!
