1Build the frame
This will be made using 3 mm thickness planks that will be cut with the laser cutter.
The main part will be a 30 by 16 by 16 mm box. Then we'll add some holes to put features such as the spoiler.Then we also make little boxes to maintain the components.
After that we use the 3d printer to make the direction. We lock the pieces togeter with little cylinder
The front wheels will be attached to this pieces.We also print gears to make the truck go forward. We put one on the motor and the other on a iron bar of a diameter of 3mm. We'll attache the Back Wheels on this bar.
2Electronic part
For the electronic part we are going to use an arduino with the code linked in the project dashboard. You need to connect an H bridge, 2 DC motors, 2 servomotors and 3 buttons on the arduino.
Connect the components to the good arduino pins (see the code)
Then in order for the components to make the truck work, you need to either screw or glue them to the truck.
The code is fully commented.
3Step 3
