CyberDeckard
A portable cyberdeck with a Blade Runner look.
Public Chat
I am interested in an arm project. Not the arm processor, but a cyberdeck that will rest on my forearm.
It is composed of a 60% keyboard and a stretched touch screen witch is about the same size.
The handle would be a Wii nunchuck. It can be for right or left handed, even with two handles. It can be use to FPV drone control.
I will design an arm in the spirit of the Voight-Kampf device with a webcam to complete the look.
The main idea has the following components :
-14 Inch streched touch screen 3840X1100 (11.8 x 35cm)
189€ https://fr.aliexpress.com/item/1005004741492600.html
- low profile TKL keyboard 29€ https://fr.aliexpress.com/item/1005005775711728.html
- two 20x40x350mm aluminium extrusion v-slot rail
- 1 or 2 removable nunchuk as pointing device
- some custom 3D printed parts (main body, nunchuck holders, screen hinge, VK head)
- SBC (typically Raspberry PI)
- power management (Ampripper)
- custom 2x5 18650 battery pack (https://fr.aliexpress.com/item/1005006259251369.html)
I received my v-slot rails. Took them bigger than needed in purpose (I know how it goes) ;o)
As they are in aluminium, they will also be good at heat dissipation.
The final length will depend of the custom rail of the 5 batteries pile.
  • Base
    IT-Wizard09/09/2024 at 07:24 0 comments
    Test print of the base. It is split to ease the print process.
    They are bolt together with M3 screws.
  • Power source
    IT-Wizard04/11/2024 at 10:55 0 comments
    Just got my 18650 stakable batteries holders. I first went with to a 2x5  batteries power source, but it seems too long (39.5cm), so I will go with 2x4.
    The batteries need to be in parallel and not in serial disposition.
    I glued the terminal ends.
  • From virtual to reallity.
    IT-Wizard04/07/2024 at 14:54 0 comments
    Screen hinge test print. Looks promising.
View all 3 project logs
Rich text editor
Richard Milward wrote 03/24/2024 at 11:49 point
Good idea, and a very neat display! BTW, you can drop everything after the first ? in those links -- the rest is just tracking crap.
IT-Wizard wrote 03/24/2024 at 13:26 point
Thanks, and thanks. Much better indeed, I was too quick on this one.
RunnerPack wrote 03/26/2024 at 15:02 point
FYI, the text has changed, but the links still have the tracking stuff (when I hover over them and look at the status bar).
