Base
09/09/2024 at 07:24 • 0 commentsTest print of the base. It is split to ease the print process.
They are bolt together with M3 screws.
Power source
04/11/2024 at 10:55 • 0 commentsJust got my 18650 stakable batteries holders. I first went with to a 2x5 batteries power source, but it seems too long (39.5cm), so I will go with 2x4.
The batteries need to be in parallel and not in serial disposition.
I glued the terminal ends.
From virtual to reallity.
04/07/2024 at 14:54 • 0 commentsScreen hinge test print. Looks promising.
