I will be creating instructables as we go along in this as well as youtube videos and I will upload them here in the details section.
This project will be to customize a skill to control the GPIO pins on a raspberry pi with the Alexa system.
Utterance.txtThis is an example utterance to use in the amazon developer skillplain - 36.00 bytes - 01/20/2017 at 22:38 |
Lambda Function.txtThis will be the base code you need to use for an AWS lambda function to work with the alexa skillplain - 1.75 kB - 01/20/2017 at 22:38 |
Interaction Model.txtThis is the base intent code for the interaction model of the alexa skillplain - 155.00 bytes - 01/20/2017 at 22:38 |
This is the first video of how to install alexa on your raspberry pi.
This next video is how to install the home assistant software:
Instructable is at the following URL: http://www.instructables.com/id/Setup-Home-Assistant-on-Raspberry-Pi/
This next video will describe how to set up your custom skill in the amazon developer portal
