1Step 1
This is the first video of how to install alexa on your raspberry pi.
2Step 2
This next video is how to install the home assistant software:
Instructable is at the following URL: http://www.instructables.com/id/Setup-Home-Assistant-on-Raspberry-Pi/
3Step 3
This next video will describe how to set up your custom skill in the amazon developer portal
4Step 4
In this step I will show how to forward your router as well as create the lambda function with AWS to host your skill.
5Step 5
This will be the final step to test out all your work.
6Step 6
If you would like to not have to use Amazon Web Services (AWS) you can use your own HTTPS and cert it with Certbot
Check out the following:
Mitch Sperry
