AlexaPi Custom Skills RasPi GPIO Control
This project will be to customize a skill to control the GPIO pins on a raspberry pi with the Alexa system.
This will be to build an AlexaPi on a raspberry pi 3 as well as install the home assistant application to work in conjunction with Alexa so that I can build custom alexa skills to control the on-board GPIO of the raspberry pi via voice commands.
I will be creating instructables as we go along in this as well as youtube videos and I will upload them here in the details section.
Utterance.txt
This is an example utterance to use in the amazon developer skill
plain - 36.00 bytes - 01/20/2017 at 22:38
Download
Lambda Function.txt
This will be the base code you need to use for an AWS lambda function to work with the alexa skill
plain - 1.75 kB - 01/20/2017 at 22:38
Download
Interaction Model.txt
This is the base intent code for the interaction model of the alexa skill
plain - 155.00 bytes - 01/20/2017 at 22:38
Download
  • 1 × raspberry pi 3 raspberry pi computing system
  • 1 × microSD card UHS-II SD card for pi
  • 1 × USB microphone Microphone to use with raspberry pi for alexa
  • 1 × Speaker Use a small 3.5mm jack speaker to hear alexa
  • 1
    Step 1
    This is the first video of how to install alexa on your raspberry pi.
  • 2
    Step 2
    This next video is how to install the home assistant software:
    Instructable is at the following URL: http://www.instructables.com/id/Setup-Home-Assistant-on-Raspberry-Pi/
  • 3
    Step 3
    This next video will describe how to set up your custom skill in the amazon developer portal
View all 6 instructions
Rich text editor
