Monitoring and controlling the environment of plants, grown in the IKEA VÄXER hydroponics set
It would be quite easy to add a water temperature and water level sensors. Or even a webcam if a raspberry pi zero w was used.
If there was any cheap way to monitor the total dissolved solids in the water, it could be used to know when more fertilizer is needed. Also, a pH probe would be great, but I think they are expensive...
I've a same Ikea system with DHT22 and Wemos. I show temps and humidity with Jeedom.
