Interaction graph Gas.jpgDescribe the interaction between each part of the gas mechanism that allow the gas chamber to release gas.JPEG Image - 208.29 kB - 06/04/2024 at 07:22 |
Interaction graph Suspension.jpgDescribe the interaction between each part of the gas mechanism that allow the suspension to strike the ground with force.JPEG Image - 173.66 kB - 06/04/2024 at 07:22 |
Spring carrier.f3dfusion - 66.21 kB - 06/03/2024 at 21:59 |
Shell guide.f3dfusion - 62.13 kB - 06/03/2024 at 21:59 |
Axle support.stlStandard Tesselated Geometry - 45.98 kB - 06/03/2024 at 21:58 |
Engine mount.stlStandard Tesselated Geometry - 179.96 kB - 06/03/2024 at 21:58 |
Code_Dangerous_Skate.inoino - 2.34 kB - 06/03/2024 at 21:49 |
SCH_Circuit-inter_2024-06-03.jsonElectric schematic (EasyEDA)JavaScript Object Notation (JSON) - 31.92 kB - 06/03/2024 at 21:37 |
Schematic_Circuit-inter_2024-06-03.pngVisual representation of electric schematicPortable Network Graphics (PNG) - 73.33 kB - 06/03/2024 at 21:37 |
Gear_4.stlGear from https://www.thingiverse.com/thing:4666006Standard Tesselated Geometry - 532.11 kB - 06/03/2024 at 20:59 |
Rack_4.stlRack from https://www.thingiverse.com/thing:4666006Standard Tesselated Geometry - 27.82 kB - 06/03/2024 at 20:59 |
Crushed Compression helper.stlPart used to compress the spring, tested with different infill (25% concentric pattern, 20% triangle pattern), both failed.Standard Tesselated Geometry - 21.96 kB - 06/03/2024 at 20:59 |
