- Accelerometers - Detect linear acceleration of devices along the x, y and z axis
- Gyroscopes - Detect angular velocity i.e. speed at which a device is rotating along the x, y and or z axis
- Both accelerometers and gyroscopes usually found inside an Inertial Measurement Unit (IMU)
- Magnetometer - relies on the Earth's magnetic field to determine the host's object's orientation related to the Earth's Magnetic North
- When combined with accelerometers and gyroscopes, can stabilize orientation calculations, and determine orientation w.r.t earth
- Accelerometers can detect the force of gravity by detecting the acceleration due to gravity along its different axes
- By itself it can measure pitch and roll (tilt) rotations but cannot measure yaw
- Gyroscope can measure roll, pitch and yaw by integrating its values
- However, Gyroscopes are prone to drift, which is why data is fused with accelerometer
- Since accelerometer can't measure yaw, this value will drift still
- By fusing with magnetometer, yaw drift will stop
- Some gyroscopes have 'self-correction' feature
