Finish assembly
10/05/2024 at 14:33 • 0 comments -
Assembly & final surprise
09/30/2024 at 11:09 • 0 commentsI finally started putting the console together. Everything was going great until I went to connect the controller. At some stage of the design I had to expand the space I had measured for the controller. I have to redesign and print the three central pieces of the case again.
Adjusting cable spacing
09/28/2024 at 09:28 • 0 comments -
Check distance cable round display
09/28/2024 at 09:25 • 0 comments -
Video Design
09/27/2024 at 18:15 • 0 comments -
Render pictures design
09/27/2024 at 18:09 • 0 comments -
Last component
09/26/2024 at 15:43 • 0 comments -
Support structure
09/26/2024 at 13:33 • 0 commentsI have added a small support, to improve stability when mounting the case
Sunday of work
09/22/2024 at 18:26 • 0 commentsNuts inserted, battery, USB cables and screens fixed, Pi3 screwed down. Correction of speaker holes. I had to file them down and will add a cover on top. I will correct the design to avoid this in the future. In the original design I put a grid that was very thin and it broke when removing the supports on the printer.
I have also reprinted the body of the lenses, to add more thickness on the face that contacts the screen. It has also been printed better.
I had to enlarge the raspberry mounting holes from M2 to M3 with a round file
Last Body Part
09/22/2024 at 07:39 • 0 comments
