Pre Assembly ;-)
09/21/2024 at 07:43 • 0 comments -
Post Production
09/19/2024 at 16:08 • 0 comments -
One more part
09/19/2024 at 08:55 • 0 comments -
Odyssey in print
09/18/2024 at 05:39 • 0 commentsI'm still having 3d printing problems. I've had to repeat parts and adjust the printer bed. It seems that finally, it's printing well.... I hope
Making off Printing
09/16/2024 at 10:05 • 0 commentsMy printer is far from being properly calibrated. I've been having problems for a while with the bed sensor and the PEI strip is due for replacement. The printer is 3 years old and since then the world of 3D printing has advanced a lot. I hope to have a new one by the end of the year. In the meantime, we will continue to struggle with this one. I'm printing parts, trying to avoid visible faces against the bed. That's why I'm using a lot of supports and it's a nightmare to remove them properly. I also got a z-jump! I'll improvise to make it as cool as possible.
First Print
09/14/2024 at 20:14 • 0 comments -
Calibrating axes and cooking in the oven
09/14/2024 at 08:03 • 0 comments -
Design completed
09/11/2024 at 19:30 • 0 comments -
Serigraphy
09/11/2024 at 19:15 • 0 comments -
Squaring the circle
09/11/2024 at 06:26 • 0 commentsSquaring the circle: The areas of this square and this circle are equal to π. In 1882, it was proven that this figure cannot be constructed in a finite number of steps with an idealized compass and straightedge.
I want to decorate one of the sides of the SWAP with a graphic of one of my favorite attempts at squaring the circle. Archimedes'.
It inspires something similar to what I'm trying to do with this console. It will play arcade games with a circular screen, which will never be fully used in the game, since they were designed to be played in a 4:3 rectangular format.
