CM4 WIFI Issues
04/25/2024 at 22:25 • 0 commentsThere were some issues getting the WIFI to work using the default rpi-imager path. I had to use an ethernet cable to connect to the pi and run `sudo nmtui` to set up the WIFI connection.
I proceeded to install all necessary applications using kiauh
Installing Klipper on the Manta M8P
I'm using the guide provided here
cd klipper make menuconfigproduced an error regarding an unsupported locale. I tried setting my locale with
sudo raspi-configbut that did not fix the error. export LC_ALL=C
export LC_ALL=Cdid seem to fix the error.
The rest of the documentation seems fine and got me to a working install. Printer is reporting errors, but that's because it's not configured yet.
Building the controller
04/24/2024 at 19:14 • 0 commentsI've bought a micro-ATX chassis to hold my controller and peripherals. I've decided to switch from Marlin to Klipper and bought the BTT Manta M8P v2 as the control board. Managed to get a raspberry PI CM4 as well for a reasonable price.
The entire thing will run on 24v, so I can't really use a regular ATX PSU, so I'm going to have to improvise and got a Meanwell 24v PSU, and I have some DC-DC converters laying around should I need them. One for 12V @ 10A, and one at 5.1V @ 12A
I'm in love with the TMC5160, so I got 8 of those. Just the standard, original, silent step sticks (from Mouser or Farnell), some soldering required.
I do want to do some case modding for fun as well, so I got 3 corsair LL120 RGB fans. First thing I did was cut of the connectors and wire them as if they were a strip of ws2812b leds, and use a simple ESP32 MCU I have laying around as the controller. Also found an old led strip with the same RGB leds to mod the case further should I want to.
Goodbye Slippy
04/24/2024 at 19:01 • 0 commentsI've scrapped my previous printer project after I had to dismantle it when moving. I was already having issues with finishing it so it seems like a good moment to start anew. Slippy never actually printed anything to did do a fantastic job as my Polarimetric Microscope
Lessons learned:TMC5160s rule.
MGN15 rails are cheap.
Motors replace pullies
E/S Pronk
