Tetoroidiv [gd0152]
A Ø17mm, water resistant BLDC servo with BT v5.2 and zero cogging.
A slotless, 4-pole servo built for Tetrinsic [gd0041].
Navigation
Prior Reading
Contents
The title tag system is explained here, and the table is updated when a change occurs. Notable logs have bold L# text.
L1
[M] Slotless motor FEMM simulation
L2
[R] New motors for the 7.2 : 1 reducer
L3
[B] Custom rotor
L4
[R] 1642 brushed motor?
L5
[M] Magnetic interference with ferrite toroids
L6
[R] Bluetooth modules such as NRF2833 MS51SF1?
L7
[T] MT6701 vs TLE5012B magnetic encoder
L8
[T] Tetoroidiv ribbon cable pinout
L9
[M][R] 16mm slotless iron lamination / coil
L10
[X][M] Peak speed problems avoided
- Increased FEMM mesh for much more reliable torque results
L11
[R] Microphone in a servo?
L12
[M] Calculation updates and 15mm diameter?
L13
[B][R] £29 BOM and 1525 BLDC
L14
[L] Designing the bluetooth BLDC controller
L15
[M] Front and back sections
- Includes rotor manufacture update
L16
[A] Bearings attracted to rotor magnets
L17
[M] 17mm SS304 Tube
L18
[A] Rotors manufactured and Paypal %
L19
[P] 9x54mm Rotors
Preface
[2024 - May 1]
Welcome to the 3rd level of "project in a project", or the 4th depending on how you look at it:
This project is the merge of a 16mm BLDC motor and "Tetrinsic PCB", currently now responsible for driving said motor as well as the following needed for #Tetrinsic [gd0041].:
  • controlling an addressable LED strip
  • reading the orientation of the BLDC rotor
  • reading a force sensitive resistor
The name is the merge of "toroid" and "derivative", with the former being because of the ferrite toroids (aka ferrite core or ferrite ring) that are used in place of traditional laminations for a slotless motor, and the latter because it's like a "3rd order differential" (if you consider Tetinventory as an integration) of the Teti project.
Initial concept render.
I'd rather not DIY a motor here, but the name is likely to stick even if I am able to acquire a commercially available motor, as the goal is to combine a 16mm BLDC with the custom PCB.
At the time of writing (and still the case 2 weeks after), 16mm motors (brushed and brushless) between lengths 36 and 59mm are only available directly from manufacturers (e.g. on Alibaba), and the prices are high (>£30/ea) considering I'd need 8 for a pair of Tetent's and 10 for a pair of Tetrescent's.
  • [P] 9x54mm Rotors
    kelvinA11/01/2024 at 09:03 0 comments
    After all these months, the rotor is no longer just a digital CAD design.
    Looking at the stickers, it seems the package was delivered by 4PX and Evri, so it's unlikely that a courier is going to send a scary letter 4 weeks from now. ABM put a lot into the packaging, using metal U shape pieces inside. There were also documents relating to the rotor measurements, such as a gauss graph over 1 revolution.
    Below is a collection of images I took of the unboxing:
    Both of these docs have a few bits of data that I don't yet know the meaning of ( e.g. kG*D, Cp, Cpk) but I can gather the geist of what these docs are talking about, so I don't think I'll need to be talking calipers to the rotors.
    Me whilst looking at the contents, feeling like I'm engineering like an enterprise:
    All these formal documents! All these intricate metal assemblies!
  • [E1][A] Rotors manufactured and Paypal %
    kelvinA10/21/2024 at 09:17 0 comments
    The rotors are ready to ship
    I've recently gotten some images to confirm that the rotors have been successfully manufactured:
    A row of 4-pole rotors that are 9mm in diameter
    I guess they're going to send the best 9 since that's all I ordered?
    The shaft has a lot more going on than it initially appears:
    The tolerances are really tight. I'm told that the ID of the bearing is 1.998mm and the shaft becomes 2.020mm OD at 0.5mm before the start of the magnets (as mentioned in the drawing I sent to them). Then, those 7mm-long knurled sections are to improve bonding between the magnets and the shaft.
    Paypal auto-currency conversion
    Anyway, I've been expecting some unexpected costs to occur between the rotors being made and them being in my hands, and PayPal drew first blood when I paid the remaining balance.
    Alibaba split transaction
    Unlike business to customer sites like AliExpress, on a business to business site such as Alibaba, it's typical to pay the order in 2 parts. What I didn't know (and have now disabled) is that Paypal saved Alipay as some "pre-approved" payment thing (see image below). Unlike usual, where pressing the button to pay with Paypal would show a popup where I can see and change settings, the transaction surprisingly went straight through.
    Paypal pre-approved payments
    I don't even know how it picks and chooses because PCBWay, for example, isn't a "pre-approved" payment.
    This was an issue because I specifically changed the transaction currency to USD because my bank gave a better rate (£59.xx vs £58.50 respectively). However, £61.06 was charged seconds after pressing the button, meaning that Paypal's relatively-pricey 2.5% rate was used instead.
    e-money conversion rate
    This is Paypal's default and you need manually change who handles the conversion for every single transaction (ie the PayPal popup) and pre-approved company (see image below). I can only assume Paypal doesn't give a global option to never use their converter because that eliminates an opportunity for a % bonus facilitating a transaction.
    Paypal's currency conversion setting for pre-approved payments.
    I'm going to mention pitfalls like these since, as explained, customers usually don't buy on Alibaba, thus online articles are usually written from a dropshipper (or other business) perspective and not some maker that needs a few pcs of a bespoke/customised part.
  • [M] 17mm SS304 Tube
    kelvinA09/15/2024 at 16:03 0 comments
    Tetoroidiv encased in a 0.5mm wall tube.
    I must've been intoxicated with hopium if I thought I could get away with not having a stiffening tube over everything. The toroid, coils, and overmould are all flexible components around the magnet, yet finger force is applied directly ontop of the motor.
    Conveniently, AliExpress has just the tube I need:
    I've modelled in a 49.5mm tube so that I've got some cutting tolerance:
    I'd also like to avoid needing a semi-circle cutout for the silicone PCB assembly, but I don't have confidence I'd be able to get away with it. Oh, but I wouldn't be able to do that anyway or else I'd block the BT signal entirely.
    Anyway, the current strategy is friction fit, potentially heating up the tube to expand it slightly before assembly.
    I'm really not a fan on how tight all the tolerances for this motor are becoming.
  • [A] Bearings attracted to rotor magnets
    kelvinA09/08/2024 at 20:43 0 comments
    The rotor's looking pretty cool.
    So I've gotten some images and updates of the rotor being manufactured at ABM Magnetics. As I somewhat worried, but dismissed / suppressed the thought at the design stage, the bearings are being attracted to the strong magnets, as can be seen in the image above.
    They've made a few and the quality seems mostly consistent. They certainly look good enough for a "we have a brushless motor at home" attempt.
    As you may understand from the Excel calculations and Fusion CAD, there's unfortunately not a lot of wriggle room to just move the bearings and give them more space from the magnetic force.
    They proposed that the were going to remake the shaft (on their dime 😀) and I said that was fine, but asked if they had tried having a thin washer between them, like the 2515 waterproof motor I saw on AliExpress.
    A few days go by and the engineers tried but unfortunately wasn't going to work so we're going with the first proposal:
    Our engineers looked for gaskets made of many materials, such as brass, ceramic, and stainless steel, but none of them were found.
    Because the thickness is only 0.5mm, our friends can't make it.
    Therefore we plan to produce the shaft and magnet again for assembly. But the delivery date may be in October.
    We updated the production drawing of the shaft again and planned to increase the tolerance of the bearing position, so that the distance between the bearing and the magnet can be 0.5mm.
    Because now the magnet will attract the bearing, making the bearing in close contact with the magnet. According to our engineers' experience, if we send the product to you now, it will not work.
    Technically, fully ceramic bearings could also be an option, but they're £2 per bearing last time I checked.
    I'm just so glad that I unintentionally found a manufacturer that could fabricate the rotor in its entirety instead of having to do the engineering thousands of miles away from the factories and have to pay for prototype and postage every time I need a respin (like the #Coaxial8or [gd0144] heatblock).
  • [M] Front and back sections
    kelvinA08/05/2024 at 09:00 0 comments
    I've finished modelling the front cap (chalk red), the front of the overmould, the back bell (orange) and the silicone moulding that holds and protects the PCB. Somewhat surprisingly, mounting the PCB is easier because of water ingress protection.
    I searched for a silicone mould kit and the first result had a nice colour so I used it in the model:
    There is a small gap on each side of the bell to allow the thin wires to get to the silicone mould:
    The bell and overmould have 3 spokes that help align to the toroid and front cap respectively:
    I also confirmed that FR-4 does not absorb water, so I should be fine in the bottom of the PCB being exposed:
    I like that the final result looks like it's just a standard servo inside a manufacturer's product catalog:
    The entire length is 63mm, with the exposed shaft being 4.6mm.
    Next steps would be to create the buildables for the servo.
    • .3MF files that can be used with vase mode
    • Silicone mould jig, perhaps adding draft angles
    • JLC assembly files
    • etc
    In other news, I received a progress update from ABM Magnetics:
    We have completed the production of rotor samples.
    However, the tolerance of the shaft was increased during production, resulting in the outer diameter of the product reaching about 9.20mm after the magnet was assembled, which exceeded the tolerance of the drawing.
    Our plan is to re-produce the shaft for production, which will be around August 25th.
    Essentially, the range of diameters was between 9.00 and 9.20mm but the tolerance specified in my drawing was 9.00 - 9.05mm. The reason for the tight tolerances is because
    • changes in diameter affect the torque constant, and
    • the rotor needs to be able to spin freely in the overmould.
  • [E1][L] Designing the bluetooth BLDC controller
    kelvinA07/30/2024 at 07:52 0 comments
    I've been working on the brushless motor PCB for the past 4 days. I'm starting to write this log when its not completely finished (I've still got the power nets to connect and the UWV pads to place), but it's to a point where I can say that a 14 x 15mm controller PCB is probably possible:
    Planning the PCB size and placement
    My expectation since the start of June was that I was going to have the 11 pin connector on the left and the 7 pin on the right, with test pads in the lower right. The 11 pin FCC should be 12mm, so that's what I set the height as. Additionally, I was thinking that the microphone was just going to complicate matters with waterproofing so I decided against it.
    However, when I drew the dimensions of the MS51SF1, I saw 2 things:
    1. The edges of the PCBs are on the 16mm curve of the motor, conveniently enough
    2. There is a lot more space between the bottom of the module and the bottom of the board, potentially meaning that I could have both FFCs (flexible flat cables) coming out from the bottom (similar to the placement of wires on other BLDC motors).
    That 0.45mm circle is the size of a via, for a point of reference. The pads are 0.6 x 2mm.
    The 2nd point was even more important as the motor and gearbox bearings go edge-to-edge, meaning that the FFCs would stick out.
    I zoomed out till the PCB was 1 : 1 scale and decided to reduce the height of the pads from 2mm to 1.8mm.
    Then I had a think about how these cables were actually going to route out, and if the 7P was on the bottom, it would only be able to terminate on the other side of the motor. If I put it on the top, I could terminate on either side. It also had other benefits, like the FSR pin being neighbours to an analog input pin, or being able to fit a testpad array:
    The vertical spacing between each pad is 1.27mm (as breadboards / through-hole pins are 2.54mm standard). I looked up the standard testpad size and one article went with 1mm ( 40 mills ). Conveniently, a 14mm wide board and 1mm spacing between pads means that the pads perfectly fit in the space.
    There also needs to be a mechanical way of keeping the PCB in place, so I converted the 4th-pad location into a 60 degree V cutout:
    I did tweak the chamfer so that the bottom edge was 12mm. In this image, it's a bit less than 11.5mm IIRC.
    Creating the MS51SF1 schematic component
    So I drew all the pins and labelled them, but then scrolled down in the nRF52833 and found out that there are 3 different packages for it and they each have different pins that are slow or are recommended for the SPI clock. I looked in the SF1 schematic and deduced that they were using the WLCSP variant, which has a lot more "low frequency I/O" pins than the aQFN I was initially looking at.
    A = Analog, S = Slow, C = SPI Clock, R = (configurable as) Reset.
    I'm hoping I don't actually need that reset pin. I don't think I do:
    Then I started the tedious process of placing pads. It didn't take long to see how KiCAD did things, but it doesn't look like grass is greener on that side. It's just a lot of addition and data entry to get the pads in the right places, and the reason why I decided to keep everything in the positive-quadrant instead of trying to make a footprint centered around the origin.
    I turned on mirror mode before doing anything, because the image shown is the dimensions on the actual module, not the footprint.
    After making the footprint with the correct pad numbers, I duplicated it and deleted the pins I knew I wasn't going to use (USB and VDD):
    Then I placed some starter gear on the board to confirm everything actually works like how it was planned:
    This time, I decided to keep the BT module on the "Top" layer.
    The DRV8311P (BLDC controller) and MT6701 (magnet sensor)
    For some reason, I can't just copy part of the old schematic and place it in the new one, so I had to "Insert Electronic Design"...
  • [B][R] £29 BOM and 1525 BLDC
    kelvinA06/17/2024 at 18:02 0 comments
    I still don't know how much shipping is going to cost, so I've just assumed that $16/motor + taxes = £16/motor. I've also just assumed that 10 PCBAs (including passives) would be £5.50 for now.
    The motor part costs £20 and the ESC circuitry costs another £9. Looking at prices for the latter, it's probably respectable considering the feature list.
    For ease of assembly, I've gone with a seemingly decent -26dB microphone from JLC's part list. It also costs 60p more, but I'm going to use the QFN package of the magnet sensor for the time being for the best chance of everything fitting.
    I am also researching into O-rings and asking if the rotor bearings can be made waterproof. Why? Because Tetent and Tetinerary are expensive and I can't just RMA it or Amazon up a new one if a spill happens, nor do I want to have to live a life of babying the device.
    I happened to find a 15mm diameter BLDC that is used for RC cars. The other 15mm I found is called the 1410 and it's a similar size but the winding offerings are slightly different. The exploded view at least gives me some confidence that my motor design isn't doing anything out of place. The rotor is only 6mm diameter by 14.5mm long, however, as well as 2 pole.
  • [M] Calculation updates and 15mm diameter?
    kelvinA06/07/2024 at 08:46 0 comments
    Tetoroidiv-16 gets a Quick Stop force of 20.7mN, which should be enough to create virtual walls at speed.
    I've gone through all the 16mm brushless motor datasheets to find the constant that converts Kt to KV, and this is the data I have so far:
    9.375
    9.4125
    9.425
    9.4257
    9.5625
    9.5583
    9.5468
    9.5523
    9.4572
    9.4589
    9.4674
    9.4174
    The average here is 9.47 which converts between mN.m to V/kRPM. To convert to V/RPM, the constant would be 9470.
    Due to the existence of 5PH belt, which should be 8mm wide, and 15mm wide FSRs, I did look into the possibility of using 5PH317 along with a 15mm diameter motor that has a 46mm rotor length. This length was chosen so that I could potentially use 50mm wide SS-430 foil.
    However, because those 15mm wide FSRs have a 10kg range instead of a 500g range (implying lower resolution for sensing forces from 0 - 300gf) and because of this paper finding out that key spacing down to 17mm does not seem to affect typing speed, but 16mm, I don't think there are suitable benefits to try for a 15mm x 150mm Tetrinsic.
    The following rotor design has seemed rather stable over these past few weeks so I've sent it to the rotor supplier:
    I like how a few notable dimensions are divisible by 9. The rotor inertia is 1.65g.cm^2.
  • [R] Microphone in a servo?
    kelvinA06/05/2024 at 07:12 0 comments
    The XIAO Sense boards manage to fit a microphone, and since I'm looking into ANC for Tetinerary, it makes some sense, especially since the Tetrinsics are planned to be infront of the ear.
    I wasn't able to find anything decent for a decent price on JLC's part library, but I have found 2 sub-£1 options on Digikey that have the full 20 - 20,000Hz of range and relatively high SNR ratios along side a -26dB sensitivity. According to the Infineon datasheet, this allows capturing the full dynamic range with 16-bit PDM, which is the max the nRF52833 supports. Coincidentally, the 833 samples at 16kHz, just like the proposed speed of the Field Orientation Control loop.
    Digikey's XENSIV page was the first thing I found on my search and the IM69D120 does seem like the best option, with a 69dB SNR.
    The SPK0838HT4H is cheaper and has a 64dB SNR, which seems more typical as most others I've seen are 60, 63 and 64dB. It also has the mic port on the top instead of the bottom, and unlike most, doesn't seem to have a shield and seems to be made out of PCB:
    There's also the IM70D122 which has a similar but not identical footprint and has IP57 water resistance.
    These microphones need 3 pins, meaning that the PCB would need 19 / 20 available GPIOs.
  • [E1][X][M] Peak speed problems avoided
    kelvinA05/20/2024 at 09:21 0 comments
    So I had the idea to actually create a simple PowerPoint animation where the orange bar would slide up and down 50mm with a smooth start/end transition to account for acceleration. Then, the time duration of both the animation and the transition to the next slide would be changed so that it looks like my finger is actually moving the slider. I found that a 0.12s animation and 0.14s slide transition achieved this without my finger doing any particular effort.
    Then I finally used the SUVAT equations in the real world for once and I got an accel value of 13.89m/s^2. Since all these measurements are kind of rough, I stuck with 2 significant figures thoughout, thus I used 14m/s^2 for my calculations.
    I then used Prusa's calculator to graph out the speed profile when doing the expected max typical movement of 24mm (each column in the Tetent layout is 6mm apart):
    I confirmed that it was 580mm/s. If you're wondering, the peak finger movement from end-to-end was 833mm/s.
    Dividing this by the circumference of the 16mm pulley, converting to RPM and then multiplying by the gear ratio and I got 5000RPM to 2sf.
    This is a bit of a problem because I still need to be able to generate a virtual wall force at these speeds, such as if the finger starts to accelerate and then hits the virual wall halfway through the movement.
    After spending a while deriving the correct equation, it's not looking good at 5KRPM:
    The equation used. A more complete equation is further down in the log.
    First row is rotations per second whilst still providing 30mN and the second row is the force applicable to the belt at 5kRPM if positive.
    Understandably, negative values all coincide with all motors with a torque constant over 10. For example, I needed to go to the TBC1636-12V to get a non-negative force of 37.8mN and that configuration uses 44% more power than the 24V variant.
    Finding the max turn count
    10 > 13.77x / 38
    380/13.77 > x
    27.6 > x
    Turns need to be 27 or less.
     I did also consider just having a higher drive voltage that would sidestep all of this, such as running the motor at 9V, but that may complicate electrical matters (not like running a motor on the same 5V rail as logic circuitry is a smooth sailing idea either) since it would be nice to have everything fully contained on Tetoroidiv.
    Actually, as I'm typing this, I'm checking motors to make sure everything is all correct, and it's not. For starters, a 1656 motor snuck into the data. Additionally, assuming 0 voltage drop on the 5V rail is likely inaccurate. All this happened way past when I usually go to sleep because, as they say, "I don't need sleep, I need solutions!"
    Anyway, 0.25mm wasn't going to make it, and since I can only have discrete coil heights, it meant that I started looking at the 0.3 / 0.35 / 0.4mm wire options. I was going to write this log talking about how power consumption has gone up 180mW just so that I could get a configuration that still had torque at 5kRPM, but I guess the sleep assisted because I've just tried a 0.35mm 21T option:
    For 0.3mm and above, there are only 2 rows of wire CSAs, meaning that I don't need to extrapolate how many turns will fit.
    Simulation with 9mm rotor and 21 turns, and the other magnet oriented to maximise the KV of the motor.
    Toroidiv against the TBC1636-12V
    110mW is the all-time lowest power consumption I've witnessed. Considering my fingers would likely be in (what the enthusiast 3D printing group calls) "sensorless homing mode", 6.4mN should be enough to set a speed limit and decelerate my finger enough to reduce the EMF enough so that the motor can apply the full torque. I'm not going to risk it though and would rather use 20 turns; the max power goes up by 6mW but the max force on the belt goes to 25.5mN at 5kRPM.
    A more complete equation to calculate the force exerted on the belt. It calculates the back-EMF at 5kRPM, which is subtracted by the minimum drive voltage. This is then divided...
View all 19 project logs
