1Step 1
Setting Up External Services
- Create a Keen.IO account (free for up to 50000 events per month);
- Add your project;
- Click on the title of the project to open an overview tab:
2Step 2
- Receive your projectID and API keys (you need read and write keys):
Store the keys securely, especially the master one
3Step 3
Node.js Application
Configuration and Installation
- Define the configuration in the LTPS Web Interface;
- Login to the LTPP3 board from the SSH client;
- Install NPM and other tools as required;
- Install the application:
git clone https://github.com/tibbotech/keenio-tutorial.git cd keenio-tutorial npm install .
4Step 4
- Launch the app:
node device
5Step 5
Comments in the code explain how it works
// requires Keen.IO client module const Keen = require('keen.io'); // requires Tibbo's humidity/temperature meter and sets it up to work with I2C line 4 const humTempMeter = require('@tibbo-tps/tibbit-30').init("S5"); // Binds the client to your account const client = Keen.configure({ projectId: "57066...........fe6a1279", writeKey: "0d2b95d4aa686e8274aa40604109d59c5..............4501378b3c193c3286608" }); // Every minute.. setInterval(function(){ // ..reads the environmental data from the meter.. var data = humTempMeter.getData(); // ..checks out if everything's correct.. if(data.status === 1){ var payload = { hum: data.humidity, temp: data.temperature }; // ..and submits them to your event collection. client.addEvent("humtemp", payload, function(err){ if(err !== null){ console.log(err); } }); } },60000);
6Step 6
Web Interface
Installation
- The web interface application can be installed on your PC, a remote server, or executed on the same LTPS device (as a separate process)
- Install the application (skip if running on the same LTPS):
7Step 7
- Launch:
node server
8Step 8
browser.jsangular .module('tutorials',['nvd3']) .controller("nodejs-keen",['$scope',function($scope){ var client = new Keen({ projectId: "5706............fe6a1279", readKey: "29ec96c5e..........746871b0923" }); // Configures NVD3 charting engine $scope.options = { chart: { type: 'lineChart', height: 300, margin: { top: 20, right: 20, bottom: 40, left: 55 }, x: function (d) { return d.x; }, y: function (d) { return d.y; }, useInteractiveGuideline: true, xAxis: { axisLabel: 'Time', tickFormat: function (d) { return d3.time.format("%X")(new Date(d)); } } } }; $scope.temperature = [ { values: [], key: 'Temperature', color: 'red' } ]; $scope.humidity = [ { values: [], key: 'Humidity', color: 'blue' } ]; // Defines Keen.IO query var query = new Keen.Query("multi_analysis", { event_collection: "humtemp", timeframe: { start : "2016-04-09T00:00:00.000Z", end : "2016-04-11T00:00:00.000Z" }, interval: "hourly", analyses: { temp : { analysis_type : "average", target_property: "temp" }, hum : { analysis_type : "average", target_property: "hum" } } }); Keen.ready(function(){ // Executes the query.. client.run(query, function(err, res){ // ..transforms the received data to be accepted by NVD3.. res.result.forEach(function(record){ var timestamp = new Date(record.timeframe.end); $scope.temperature[0].values.push({ x: timestamp, y: record.value.temp.toFixed(2) }); $scope.humidity[0].values.push({ x: timestamp, y: record.value.hum.toFixed(2) }); }); // ..and does rendering $scope.$apply(); }); }); }]);
9Step 9
index.html
<html> <head> <link href="http://cdnjs.cloudflare.com/ajax/libs/nvd3/1.8.2/nv.d3.min.css" rel="stylesheet" type="text/css"> <script src="https://ajax.googleapis.com/ajax/libs/angularjs/1.4.2/angular.min.js"/> <script src="https://cdnjs.cloudflare.com/ajax/libs/angular-nvd3/1.0.6/angular-nvd3.min.js" type="text/javascript"/> <script src="http://cdnjs.cloudflare.com/ajax/libs/keen-js/3.4.0/keen.min.js" type="text/javascript"/> <script src="http://cdnjs.cloudflare.com/ajax/libs/d3/3.5.16/d3.min.js" type="text/javascript"/> <script src="http://cdnjs.cloudflare.com/ajax/libs/nvd3/1.8.2/nv.d3.min.js" type="text/javascript"/> <script src="browser.js" type="text/javascript"/> </head> <body ng-app="chart" ng-controller="nodejs-keen"> <h3>Temperature, C</h3> <nvd3 options="options" data="temperature"> <h3>Humidity, %</h3> <nvd3 options="options" data="humidity"> </body> </html
