Day 6 (05/12/2024)
05/21/2024 at 01:52 • 0 commentsBoard Layout
Spent most of the day working on laying out the VU meter components along the half-circle. This was before I finalized the component selection for the LEDs and the diode ladder.
For the final layout, I changed the orientation of the LEDs. I also used lines from the center of the half-circle. The angle between the LEDs is about 18 degrees with an 9 degree offset from 0 and 180 degrees.
After laying out the components. I moved the VU meters lower down the card.
Day 5 (05/11/2024)
05/21/2024 at 01:49 • 0 commentsBlock Diagram
Decided on making a VU Meter. Below is the inital block diagram of the system.The filter cutoff frequencies were taken from https://www.amplifiedparts.com/tech-articles/audible-frequency-range-and-describing-tone.
Board LayoutStarted to layout the graphics for the VU meters. The VU meter is going to be a half-circle with the specific tonal bands labeled in the middle of the half-circle.
Days 3 & 4 (05/09/2024 - 05/10/2024)
05/21/2024 at 01:46 • 0 comments- Head Empty
Day 2 (05/08/2024)
05/21/2024 at 01:46 • 0 commentsIdeations1. 555 Timer based guitar pedal
2. A 741 and 555 based oscillator circuit
3. Mini-synth
4. VU meter
Day 1 (05/07/2024)
05/21/2024 at 01:45 • 0 commentsIdeations - Head empty. Try again tomorrow.
Setup
- Created base KiCad project
- Created base Git repo
