The screen is back.
Turns out, the backlight itself was ok - it's these little buggers are probably at fault here, which are LCD backlight step-up converters. Meet CPC2123ST-A2 and ACT6311UC.
They get their EN signals alright, they get their 5v in, but they refuse to step that voltage up and my assumption is that they were damaged when primary converter was releasing magic smoke.
Not gonna bother reversing that circuit, but i will say that for some reason output cascades of these fellas are in parallel and go out to the high side of LED backlight output.
A day ago i've ordered this "universal backlight replacement kit" that comes with long but thin PCB-based LED strip and it's corresponding driver circuit. So you can replace any backlight there is i guess.
Electrically wise it's almost a drop-in replacement, these scaler boards also have, apparently a connector for external backlight drivers which is hella neat:
mkdxdx
