Door entry tools! They need to fit in a wallet for easy carry. I'll start with a basic latch shim, with some decoration for grip and a hole for a pull-cord. I'm designing it to be cut from sheet steel with a laser or water jet. If all goes well I can also make a lockpick set.
The shapes will be designed in Inkscape because it's open-source and designed for drawing abstract shapes like this.
Maave
