Longer battery life
06/22/2024 at 22:13 • 0 comments
In order to extend the battery life of the original PiPod project, a few changes were made:
1) Changed the LCD screen to an e-paper screen.
The LCD backlight was consuming a lot of power (~40 mA), and the e-paper screen does not require illumination in ambient lighting conditions. So you can see the screen without stressing about draining the batteries.
2) Replaced the Pygame graphics engine with the Python PIL (pillow) graphics library.
3) Replaced the Pygame event que with the Python "keypad" and "digitalio" libraries.
These two changes eliminated the power-hungry Pygame task that was always running in the background -- it reduced the power consumption by 9.5% while idle, and by 5.3% while playing music, which is significant.
4) Changed the OS from "raspios-bookworm-arm64" to "raspios-bookworm-arm64-lite".
The "lite" version of the OS does not have a graphical user screen, so it boots faster and also eliminates a lot of unnecessary tasks/processes running in the background.
5) Reduced the ARM core and ARM bus clock rate down to 150 MHz.
With so little software running, there is no need to clock the CPU at the default clock rate of 1 GHz. Reducing it to 150 MHz saves about 20 mA. (Note: There is no measurable power consumption reduction seen when disabling unused ARM CPU cores.)
How Long Does the Battery Last?
In my experience, the original PiPod had a battery life of about 2 hours using a 1200 mAh battery.
Compare this to the ePiPod, which, when playing music non-stop, at normal listening volume (with the same 1200 mAh battery), now has a battery life of nearly 5 hours.
Status: 22 June 24
06/22/2024 at 21:41 • 0 commentsLog #1
Here is where the project stands today (22 June 24):
I have assembled the PC board, and it works as expected. This version was built from the gerbers (and BoM) that are attached to this Hackaday project.
I have iterated the case files a couple of times. The most recent version I fabricated was mostly acceptable, but could be improved with some minor modifications. I made those modifications, and the .STL files are attached to this project.
I am currently fabricating the case files according to the attached files, but I have not received them yet. (I expect them to be very good, if not perfect.) I will update the project once I use them to assemble a unit.
UPDATE: The Rev3 (current) case files are acceptable.
SOFTWARE:
The software is stable, and works well.
All source files are posted on github at: https://github.com/delhatch/PiPod_ePaper
