1How to add components
To add a component to the canvas, click it or drag it from the component library onto the canvas.
2How to move and rotate components
To move a component, hold your mouse pointer over it and press "m", or simply drag it:
To rotate a component, hold your mouse pointer over it and press "r":
3How to draw wires
To start drawing a wire, click on the pin of a component or press "w". To finish drawing click on another pin (or double click outside of a pin):
4How to configure a component
To configure a component, double click on it.:
5How to switch between schematic and layout
To switch between schematic view and layout view, use the tab buttons:
