I 3D printed my initial version of the case. The magnetometer board fits in it's spot, and the magnet fits in it's well, but I expanded the the diameter of the well to get more movement. The M2 button caps interfered with the magnet movement, so I made the well a bit deeper. I also added a space for the power switch
Revised Version:
The upper shell was too thick, so the circuit board didn't fit. So I increased it's diameter a bit. I also spllt the upper section into two pieces.
Revised Version:
