• 1
    Step 1
    1- connect the ESP32, the waveshare LCD and the SD card reader as the following  table. all VCC to 3.3 v
    waveshare pin
    SD card
    SPI  name
    esp32 pin
    DIN
    MOSI
    MOSI
    GPIO 23
    CLK
    SCK
    SLCK
    GPIO 18
    CS
    Chip Select
    GPIO 5
    DC
    Data Command
    GPIO 2
    RST
    REST
    GPIO 4
    BL
    Back Light
    GPIO 15
    MISO
    GPIO 19
    SD SC
    GPIO 13
    2-copy the business_card_final.ino from files folder to your PC
    3- load the program to the ESP32 using arduino IDE. you will see zameel business card displayed on the LCD
    4- insert the SD card in the SD card reader
    5- log your device (PC, phone ……..) to zameel business card network. the password is 12345678
    6- using any web browser open 192.168.4.1 page
    7- it will display the following page
    8- fill the form and submit the information . the web page and LCD will display       the information and the same information will be saved in the SD card.
    9- with every new submit the display and the web will change but the SD card      will keep the record for all summations
    10- remove the SD card and insert it to the PC. open data.txt. you will see all the submissions information
    I will appreciate all comments and suggestions
