DIY Dive SONAR using Open Echo
07/14/2025 at 18:24 • 0 commentsI built a working dive SONAR using Open Echo.
This lets you "see" in water with low visibility and has a range of at least 25m. (couldn't test further)
I is CNC machined from a big block of PE, runs on a raspberryPi, 7" screen and the All-In-One development hardware of Open Echo.
new Open Echo Interface Software
07/14/2025 at 18:19 • 0 commentsOpen Echo has a new Python Interface software for easier data viewing and some settings. You can also send NMEA-compatible data to other software like openCPN or i-Boating for depth information.
Getting Started Guide: https://github.com/Neumi/open_echo/blob/main/TUSS4470_shield_002/README.md
Jan Neumann
